Question about HP LaserJet 2420 Printer
Double side printing issue with HP 2420
I would like to get help on double side printing setting on the printer.
The printer is on network, when i want to print double side printing, the printer options setting only give me (double side printing manually). Just want to know how would i get to auto print. There only one computer in the office were able to auto double side printing (printer page one side and pull back into the printer and print the other side). Please advice.
  • 96 Answers
Try to default on your page setup.
Posted on Jun 16, 2008
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
I am using a hp laserjet 2420n printer and i have been trying to print on both sides of the sheet but i cant
For details, please click on this link and follow my instructions :- http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Aug 13, 2011 | HP LaserJet 2420 Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
Could not printing double sided in operating system windows 7. Please help.
Hello, I would assume a new driver has been loaded, Go to your printers folder, Check the under the printer properties and the device setting, make sure the duplex option is enabled.
http://www.fixya.com/uploads/images/prefab_21.jpg
Jan 18, 2011 | HP LaserJet 2420 Printer
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
Mar 10, 2009 | HP LaserJet 2420 Printer
Mirror effect on hp 2420 PCL6 (network)
Try downloading the Postscript driver instead of the PCL6 driver. There have been a lot of issues in the PCL driver. You might also try the universal driver. Both are list and can be downloaded from HP's website under the support icon.
Hope that helps you.
Sep 25, 2008 | HP LaserJet 2420 Printer
HP 2420 Issue
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Jul 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Problem
Go into your print setting and check the box the has 'print on both sides'. It can easily done if you installed the HP toolbox software.
Apr 29, 2008 | HP LaserJet 2420 Printer
Hp printer 2420 is double printing same paper side
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 20, 2008 | HP LaserJet 2420 Printer
LaserJet 2420 pdf printing issue
Hi within the driver printing preferences you are able to change the graphic mode if you do this it may help. Without seeing what you are trying to print cannot give a accurate answer so try this and get back to me if this doesn't work
Hope this helps you and please rate me
Thanks J
Dec 04, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
816 people viewed this question
Ben Johnson
