Question about Graco Digital Deluxe Imonitor Baby Monitor
My discard light (red light is constantly on). Is the battery dead or do I need to just reset the monitor? Do I need to but a new battery? This is only six months old, I don't think I should need a new one. Why is this happening? Thanks.
My Sanyo VPC-T1496R camera is dead. What is wrong?
It depends on what type of battery it uses. Some batteries once they have fully discharged are not able to recharge
Aug 20, 2015 | Sanyo Cameras
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced.
When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
I have constant red and green flashing lights on my charger
The red and green flashing lights on a Ryobi charger is a dead battery, or defective, won't charge. I hope that is what you are talking about.
Nov 15, 2010 | Grinders
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
MOTOROLA RADIUS GP900
Unprogrammed channels will have a constant tone. It is possible your radio is unprogrammed. A dead battery tone is only for a moment, and is usually a medium tone then a low tone, sounding somewhat like beeedeeep.
Dec 06, 2008 | Radio Communications
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Jun 18, 2007 | JVC KD-S570 CD Player
Graco Digital Deluxe Imonitor Baby Monitor Logo
311 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
