SOURCE: Canon ImagePress C1 error E000747-8000
E747 from what I remember is the connection cable from either the scanner to the print device, or scanner to the copier. Make sure that none are loose and they are in the correct slots.
Mismatching the cables may result in the error.
SOURCE: error e020 0180 on canon imagepress c1 please give
November 02, 2010
Product : imagePRESS C1 / C1+
Title : E020 with Multiple Sub Codes for all Colors
Problem :
E020 with Multiple
Solution :
Check for a pinched or
damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the
Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209
back to the Rear Driver p.c.b. connector J3802.
Canon USA, Inc. Systems & Technical Support Division
SOURCE: Canon ImagePress C1 has error
Hi
This error is caused due to faulty thermister
however; you can check the fuser unit for any jammed paper around the upper
fixing roller and try to clean that area. After this is done try to clear the
error by entering the service mode, to enter press Additional functions, #.
Then go to #7 Printer and press OK, then go to #4
printer reset and press OK, yes= *. If the issue returns then replace the
thermister. Hope this helps...please post back for further assistance.
Daniel
SOURCE: I have error code E000732-0001 on Canon imagepress C1
Dear Sir/Madam
My machine Error E00732-0001 Can't clear and repair.
Can help me.....very thank.
