Question about Singer 3116 Simple
My needle will not go down enough to thread the bobbin
    Genius:
  • 1,788 Answers
I would call Singer at 1-800-4singer, because that is the first time I ever heard of this problem, usually, it the opposite problem, that the needle hits the bobbin. Maybe, you machine has a defect.
Posted on Sep 27, 2010
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
I cannot get the upper and lower thread to catch when I try to sew... I've gone over the manual and done everything over and over... what could I be doing wrong? Thanks so much for any help
First your tension might be wrong. You should be able to pull it with little to no resistance. It is a feel thing you must learn. Also the bobbin might be too tight. There is an adjustment screw on the bobbin. You should also have this medium to tight. To tight and it will not knot with the top thread. Finally most of the time the needle is just not going down far enough into the bobbin area. Needle might be too short. If it is just let it down a little. Also very important that you have the groove on the needle facing the direction called for in your machine.
Jun 02, 2016 | Sewing Machines
Thread keeps coming out of needle when sewing
When you start sewing, make sure the thread is long enough so the machine does not pull the loose end down into the bobbin casing. It is best to drawn both threads (bobbin and top thread) up through the pressure plate before you place the fabric under the pressure foot.
Mar 23, 2016 | Sewing Machines
On a Singer Quantum 9940, the upper thread will not 'catch' the bobbin thread. What should I try to do?
Make sure that your needle is all the way up. With many needle clamps, loosening it enough to remove a needle is not enough to insert one -- you have to loosen it a little bit more. You can determine that by looking right above the clamp on the shaft -- there is what looks like a grey bar and the end of the needle should be right under it. If your needle is too low, it will not catch the thread.
May 24, 2014 | Singer Quantum 9940 Computerized Sewing...
Why wont my needle pick up my bobbin thread
1. Either the needle is smaller than required and does not reach down enough to loop the bobbin thread.2. Or the bobbin thread is not kept out of the shuttle and does not make a loop with the needle thread.
Apr 05, 2012 | Brother Sewing Machines
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
Sep 10, 2010 | Kenmore Sewing Machines
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
Husqvarna Vicking - The bobbin thread is knotting
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Dec 04, 2009 | Husqvarna Viking 1
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Good luck.
May 19, 2009 | Husqvarna Freesia 415
Loop formation between bobbin and needle
Not enough info provided but will provide procedure for testing tensions:
Good luck.
Jul 14, 2008 | Husqvarna Freesia 425
Singer 3116 Simple Logo
41 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
