This is how you put music on PSP:
1. Connect your PSP with your PC using the USB cable.
2. Use your PSP interface and hit HOME button, and then go into "Settings". Here you will have to use the directional button to find "USB Connection"
3. Once the connection is made, you will need to check your PCs available drives. You can do this by going into "My Computer". Your PC should detect your PSP as and additional drive. It is not much different from using portable drive or thumb drives actually.
4. Click on your assigned PSP drive.
5. Create a new folder call "music" on your PSP drive
6. Select your MP3 music from your PC and drag it into your "music" folder on your PSP. Note that all this is done in your PC interface.
7. When all the desired MP3 are transferred, get out of the USB connection mode by pressing "O" on your PSP.
8. Find the music area in your PSP, and select your memory stick. Search for your "music" folder and you are good to go.
SOURCE: putting music on PSP!!!
Using a USB connect to your PC , then put your MP3 on music folder. just use compatible USB then go to your psp USB enable.
