Question about ASK Proxima Proxima DP2000S Data Video Projector ( DP-2000S, DP 2000S ) Multimedia Projector
Same problem- shuts off automatically
I am having the same problem. An error message comes up that it is over heating, then the power shuts off.
Please help!
ReneeMCA
    Problem Solver:
  • 6 Answers
Possible Solutions:
1) First thing could be that depending on the location where this is installed could be altitude related as some projectors run differently at higher elevations with thinner air/humidity.
2) If this is not the case then then most likely the thermistor placement on the inside of the projector that detects the internal temperature to protect the internal hardware has moved or is defective. If this Thermistor switch has moved slightly this problem occurs. The solution is to send it in for inspection and adjustment.
3) There is either a fan disconnected internally or one of the fans may have gone bad. Solution is to send it in for inspection
Hope this helps
Posted on Nov 18, 2008
How do you access the filters for cleaning?
Posted on Nov 06, 2008
Buy a PLUS brand projector
Posted on Aug 26, 2008
  • 115 Answers
Clean the air filters and also check the fan is working for proper
air circulation.
Viren
Posted on May 25, 2008
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
I have a Goodman 80% efficient furnace - the blower motor will not shut off unless I kill the power - when I power it up and call for heat it will fire up as it should - ventor motor comes on / Flame...
you could try check the AFC automatic fan control which brings the fan on temp rise and shuts off on temp fall, see if its clean on the back of it, check filters are clean try cleaning flame sencor , the afc inside the cover the temp dail turns back when cooling see if this sticking none of this will cost you, just time.
Sep 21, 2011 | Goodman GMS90703BXA Heater
The system reboots on its own. especially when streaming video from the interent.
When a system reboots on its own thats usually a sign that either 1. Your cpu or computer is overheating or 2. that your power supply is insufficient to power everything you have.
Did you recently make any additions to the computer? upgrades? If so verifiy the power supply is strong enough and you may want to purchase a new one. a 600-650w Power supply should be sufficient to power almost all home computers and can be found cheap on sites like newegg.com.
Check and see if the computer is hot to the touch (be careful). If it is you may need to clean out fans, install more fans. Check the processor heat sync make sure the fan is working. Install thermal paste if you dont have it between the processor and heat synce etc. To cool it down. Also you may want to move the computer out some so it has room to breathe, It shouldnt be stuck in a small/tight area.
One other thing it could be is you could have it set to automatically reboot upon receiving serious errors with windows. You can turn this feature off to see if errors are the cause. to do so (from the Microsoft Site)
Microsoft Windows XP
  1. Click Start, and then right-click My Computer.
  2. Click Properties.
  3. Click the Advanced tab, and then click Settings under Startup and Recovery.
  4. Under System failure, click to clear the Automatically restart check box.
  5. Click OK, and then click OK.
  6. Try to reproduce the error message.
uparrow.gifBack to the top Windows Vista
  1. Click Start vistastartbutton.jpg, click Control Panel, click System and Maintenance, and then click System.
  2. Click Advanced System Settings.
  3. securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. Click the Advanced tab, and then click Settings under Startup and Recovery.
  5. Under System failure, click to clear the Automatically restart check box.
  6. Click OK, and then click OK.
  7. Try to reproduce the error message.
Once you do this if it gets an error rather then rebooting you will be greeted with a blue screen and error. you can copy down the error message and come back here for a solution.
Good luck.
Feb 15, 2011 | AMD GIGABYTE GA-K8N51GMF-9 NVIDIA GeForce...
HP Pavilion dv4000 Laptop There is a error message coming on my screen it says "104-Unsupported wireless network device detected . System Halted . Remove device ad restart." .I was cleaning my Laptop as...
Try the connectors near the WiFi receiver. The message is relative with thw wireless section. Try remove it from the device manager and reinstall it.
Stelios.
Feb 23, 2010 | HP Pavilion dv5000t Notebook
Mobile automatically shut down
Your phone is set to work only with
certain SIM cards. Check if you are
using the correct operator SIM card.
Jan 09, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
PC keeps shutting down and then re-boots automatically about every 20 minutes .
Shut it down.
Remove the power-cord.
Buy a can of compressed air ($3 to $5).
Remove the side panel(s).
Hold the can of air vertically (do not tilt it),
and blow away the dust from everywhere: inside the power-supply,
between the "blades" on the heat-sink & fan on top of the CPU.
Replace the side panels.
Reconnect the power.
Start it up.
Click Start
Right-mouse click on My Computer
Choose Properties
Choose Advanced.
Under "Startup and Recovery", click "Settings".
Click to disable "Reboot Automatically".
The next time that it crashes, what error-messages _stay_ on the screen?
Oct 10, 2009 | Microsoft Windows XP Professional for PC
HP computer is frozen and won't shut down, even by the off button. It just comes back on automatically still frozen. It's not my computer. My friend can't get online, but she could call you, if you think...
If you still cannot shut down even by the off button next time, you can remove the power supply/off the main supply.
leave it for 30 sec and restart again. If the problem still occur, check your registry.. you can get more info from below link
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
Nov 01, 2008 | Computers & Internet
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
ASK Proxima Proxima DP2000S Data Video Projector ( DP-2000S, DP 2000S ) Multimedia Projector Logo
259 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
