Question about Sub-Zero 685/S Stainless Steel Side by Side Refrigerator
I have a model 685 refrig...error code flashes 40 and 50 with EC at the top?
5 Suggested Answers
SOURCE: My Service light is blinking and there is an EC 50
Try powering refrigerator/freezer off for 1 minute and then repower back on which will clear the error code. If EC 50 rror code does not come back, it was posible you 1) had a house power failure interruption for a period of time and the compressor had to work extra hard to catch back up. or 2) also check to see that a door is not being held slightly ajar and is being blocked by food making the compressor run too much.
Posted on Jun 16, 2010
SOURCE: sub zero ref 690 s model with error code ec 50
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
Posted on Jun 23, 2010
  • 552 Answers
SOURCE: Model 685 Manufactured 02/04.
More than likely the control board in the refrigerator section has failed. The only thing that would cause this issue it a control. The breaker reset was only resetting the software in the control board.
Replace the board on the side and it will fix this issue.
Posted on Apr 13, 2011
bobicehouse
  • 1524 Answers
SOURCE: "service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Posted on Jul 07, 2011
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
EC ERROR CODE
It means the unit is low on gas
May 19, 2014 | Midea Heating & Cooling
Remote code for Panasonic TV using my Dish Network remote? I have had Dish TV for several years and have misplaced the manual with the codes. Thank you
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to program your remote to your TV you will need to first locate the model number of the remote. The model number of the remote will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best remote codes for our more popular models of remotes. I hope you find this information useful and if you have any further questions or concerns feel free to email directly at Cheri.Torres@Dishnetwork.com.
Remote model Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 700, 734, 512, 573, 234, 765, 644, 811.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 685, 512, 734, 700, 644, 811.
4.0 and 4.4 IR/UHF remotes - codes 644, 734, 676, 512, 765, 234, 811.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 700, 234, 512, 644, 734, 685, 765, 811.
20.0 IR and 21.0 IR/UHF remotes - codes 512, 876, 780, 619, 860, 508.
Instructions for addressing remote to the TV.
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all mode buttons light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 12, 2011 | DISH Network IR Remote Control
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero ref 690 s model with error code ec 50 what is that
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Control panel is reading EC but numerical code...temperature reading is erratic as well. I turned the unit off and waited for 5 minutes and then turned it back on. I don't hear the unit running and EC is...
This is you electronic control board that is going out. You should probably repalce it as soon as possibel to prevent further parts from going out on your Sub Zero.
We are Sub Zero Parts Suppliers and will be happy to get this board out to you asap if you will contact us.
We hope this solves your problem and we look forward to being able to assist you with other appliance issues.
Nov 05, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Subzero 690 flashing EC and service
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Feb 20, 2008 | Sub-Zero 690 Side by Side Refrigerator
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Sub-Zero 685/S Stainless Steel Side by Side Refrigerator Logo
218 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
