Question about Bissell 5200 Upright Wet/Dry Vacuum
My cleaner came with brushes in addition to the cleaning pads. Can't find the manual...when should we use the brushes. Thanks!
  • 276 Answers
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Posted on Sep 27, 2010
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
When we put our spot bot cleaner on automatic the cleaning solution does not come out. The machine goes through all the cycles but the area is completely dry with no solution passing through the brush.
Good afternoon,
It sounds like the spray tip may be clogged. This is all referenced in the product/service manual located here:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000074938.pdf
There are numerous points of reference in the manual, specifically on page 14:
I hope this helps. If you need clarification or additional assistance, let me know. Have a great day, and please rate this solution!
Thanks,
~PCF
Mar 07, 2011 | Bissell SpotBot Hands-Free Compact Deep...
I have a hoover carpet cleaner with the 6 brushes and they have stopped turning i have cleaned the little screen and still no results what may be the problem
i found a copy of the manual on the inter net and was looking through it and it told me how to takemy brush assembly out, so i did that and replaced my brush assembly. it was really easy and only cost 25.00. thanks for the help
Marilyn Lambertson
Jun 20, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook the parts for cleaning furniture
How to Clean Wooden furniture The tips below explain how to clean wooden furniture, but an essential part of everyday maintenance is to place protective mats or pads under them to prevent the wood from scratching - otherwise, your efforts will be in vain.
  • If you're wondering how to clean wooden furniture on the regular without much hassle, regardless of the wood finishing, you should get rid of the dust first.
  • Make sure to attach a dusting brush to your vacuum cleaner to remove the dust on your wooden furniture to avoid scratching it. If you do not have a dusting brush attachment, opt for a soft microfiber cloth instead.
  • Then apply a specialized wood cleaning product - always follow the instructions on the label, and choose your product to suit the finish on your furniture. Read on to find out which to use
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 17, 2008 | Vacuums
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
User Manual for Electrolux Model 1522 Double Insulated Floor Shampooer
I just bought the Electrolux Floor Pro Encore at a yard sale and need the manual. The URL above isn't working for me. What am I doing wrong.
Mar 23, 2008 | Vacuums
Bissell 5200 Upright Wet/Dry Vacuum Logo
23 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
