Question about Thermador SGS36GS Gas Cooktop
We have a Thermador SGC365R which was installed in 2000. The center two burners (extraLow burners) have never worked, but we had no authorized repair people in our area so they never got fixed. An unauthorized repair person came today and said he would need another persons help, and he might break some parts while trying to repair it. Does this sound right? Also, is this something you could do yourself?
  • 205 Answers
Hello- The extra low simmer burners are indeed troublesome. Sometimes you do have to drill-off the burners, sometimes all of them. This is can be very time consuming depending on if you have the right tools. The issue is you have to get the top off the unit in order to access the spark module and switches that come with the Potentiometer kit (the parts they will need to replace). As well, they will have to replace the Venturi Tubes that were drilled off and the orifice holders as well because the venturi screws into this. I would get a parts cost and labor estimate and consider also the cost of installing a new cooktop. I have done many of these, it's the same on their ranges, and it can take a couple of hours. I will say that I have never needed another persons help to do the repair. Hope this helps, best regards.
Posted on Sep 28, 2010
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Thermador Cooktop psc486glzs low burners not working
hi my name is mark, i called thermador and the tech.is correct they have switched to 110v valves. thanks for your question.
Feb 18, 2009 | Thermador PSC486GLZS Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Thermador SGS36GS Gas Cooktop Logo
941 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
richie46
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
