Question about Vacuums
November 2008 I bought a Simac Stirella 9000D steam generator iron. Recently its been leaking water out the bottom of the regenerator. It makes a noise when it is trying to get the steam to the iron and it works then but afterwards when the noise stops it stops steaming and I find a puddle of water underneath the regenerator. Also a little steam comes out of the water tank at the top. I understand this is happening because of scale in the base unit. Can I get something to get rid of the scale? - I know this isnt normally necessary but its stopping the water getting to the iron. I have only regenerated the filter twice in 20 months probably should have done it more as the test said every 6 months! Also as I was getting some scale coming out of the iron started to use half tap water and half distilled water as it worked well with my ordinary steam iron Is there anything I can do to sort out my iron?
  • 17 Answers
SOURCE: Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Posted on Mar 11, 2008
heatman101
  • 43501 Answers
SOURCE: have a shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Posted on Jan 28, 2011
p_sodi
  • 29 Answers
SOURCE: Using my hoover steam vac tonight and too much
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Posted on Feb 25, 2011
mnwarfield10
  • 452 Answers
SOURCE: how do i change filter
take old one out /// fill new one with water but put finger under hole ... replace.
Posted on Feb 27, 2011
  • 250 Answers
SOURCE: I have a stirella dual
It sounds like the steam valve inside the iron is stuck open. You have to take the iron apart and free it up by lightly scraping water deposits off it with a screwdriver.
Posted on Mar 16, 2011
Why is my iron leaking water from the sole plate
Can be two things
It needs descaling.
You are storing it sole plate down with water in it.
Oct 06, 2015 | Morphy Richards 42220 Power Steam Elite...
Simac evt 100 steam cleaner
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Mar 30, 2014 | Vacuums
Power steam elite not registering descale
We had this problem whilst still in warranty. Without question they sent a new iron. We have only used the di-ionised water in the new one making descaling much less painful
Jan 12, 2014 | Morphy Richards Power Steam Elite 42221...
I have a SIMAC steam iron that isn't performing well at the moment. I think it needs descaling as it is making a large whistling sound when I turn it on and it has heated up. Can someone tell me what...
To clean the reservoir of your iron, pour a solution that is one part vinegar to one part water in. Turn the iron on. Allow it to steam for about four minutes. Drain the iron for an hour, and be sure to repeat the process with clean water before you iron any clothing items.
Jun 20, 2011 | Vacuums
I have a stirella dual steam iron. At present it is constantly steaming even though the steam button is not clicked in place. How can I fix this?
Mar 16, 2011 | Vacuums
How do i change filter on my Stirella Simac iron
Feb 27, 2011 | Vacuums
How do you take the casing of a stirella Simac SX4520D steam iron?
It have a torx-plus T20 screw horizontal under the handle.
Sep 26, 2010 | Vacuums
Steam builds up but does not come out of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 19, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Vacuums Logo
176 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
