Question about TallyGenicom 6312 Matrix Printer
Printer TallyGenicom T6312 printing blank pages
  • 21 Answers
This is most likely caused by a problem with the print gap mechanism. It seems the print gap sensor was not able to adjust the gap correctly for your paper. The first I would try is to update to the current firmware version (4.0A) which is in many times solving the problem. If not you would need to replace the print gap sensor.
Posted on Dec 03, 2010
I need the procedure to enter a new ip in a tallygenicom 9022. we can print out he old address but cannot get info on putting in a new one
If the printer already has an IP address and you know what it is by printing a config page, the simplest thing to do is connect a pc directly to the printer using a cross over network cable. Ensure the IP address in the PC is in the same range as the printer ie only the fourth octet is different. Ensure you can PING the printer Enter the current IP address of the 9022 in a web browser and it should take you to the printers internal web page whic will allow you to change network settings. An alternative option is to use the ARP command at the DOS prompt, for this you will need the MAC for the network card on the printer, this will be on the printed network config page and on a lable on the network card. For help on the ARP command type; ARP /? At the DOS command propt on a PC. A third option is to use a software utility called SYNCTHRU supplied on the installation CD that was with the network card when new.
Aug 22, 2011 | TallyGenicom 9022 Laser Printer
I am not able to take the print from tally
to print anything from telly
go to the page you want to print then hit alt+p
on right side hit the button select printer
set your printer in it
hit enter and accept
now you can print from tally.
Mar 05, 2011 | TallyGenicom 2265+ Matrix Printer
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
Printing runs
Your rollers are either dirty, or worn unevenly, these need to be attended to to fix your problem.
http://www.tallygenicom.com/default.aspx
Support page above, your service manual and info at this link below.
http://www.fixyourownprinter.com/forums/printer/49975
Jun 10, 2010 | Tally T2250 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Printing only black in TallyGenicom 8108N
You can change the colour setting in the printer driver to Black Only, this means you will only print Black and White using only the black toner.
To make this change on Windows XP;
Open the Printers and Faxes Folder.
Right Click on the printer driver for the 8008.
Select Printing Preferences.
Click on the Color/Print Quality Tab.
In the Color Mode section select the B&W radio button.
Click on the APPLY button
This should change the pritner driver to print only black and white.
Mar 23, 2010 | TallyGenicom 8008 Laser Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
TallyGenicom 6312 Matrix Printer Logo
462 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
