Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Where and what does the heat sink look like? To look at the cp150 to see if its swelled
  • RCA Master
  • 5,138 Answers
Just replace the deflection board 125.00
Posted on Sep 17, 2008
Where is the horizontal output transistor exactly?
So Far You've Done Very Good, The Horiz Output Is Located Very Near Or On The Flyblack Panel, It 's Usually A Rectangular Transistor Mounted To A Very Large Silver Like Heat Sink ..It Does Sound Like It's Shorted, But If Not,Check The Focus Divider Or Hv Tripler..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hdtv (2004) d52w20b
I posted this a while ago, but it applies here, This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20b wont turn on
I posted this earlier, but I believe it applies here to:
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
Rca d52w20 will not turn on.
I posted this earlier, however I believe it applies here too:
I hope this helps,
Shuttle83
RCA D52W20 won't come on
I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Did you get your D52W20 fixed?
I posted this earlier but it applies to the problem you are having:
I hope this helps,
Shuttle83
I hope this helps,
Shuttle83
42" RCA Rear projection
Hello Coloradolacy,
This set may cost you all of $5.00 to repair.
First I want you to unplug the set and look at the board containing the IHVT (called the flyback transformer by some) in the middle of the board you will see a heat sink and in the middle of the heat sink or close by you will see CP120, CP140, and CP150 one or all of these capacitors will appear to be puffy (bloated) with the top part pushed out. Replace all of the ones that look like this (puffy or bloated) That is your problem, the value of the CP150 is 2200uf 16dcv this one is usually the problem. It will cost you about 2.50 or less at radio shack.
I hope this helps,
Thank you,
Shuttle83
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 42" Rear Projection TV
I have posted this before, and I believe that is fits this problem too, This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
