Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ihave a craftsman 20 horsepower riding lawn mower. It starts fine but it barely moves. It stops moving. Seems to have no power, especially if on a slight slope. I had a new clutch installed, but still does the same. Can anyone please tell me what the problem is. Is it the transmission?
    Brigadier General:
  • 3,911 Answers
Either your drive belt is loose or your transmission is going bad.
I would have another mechanic, not the one who installed your "new clutch" take a look at it.
Posted on Sep 27, 2010
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
We have a 1 yr old Craftsman 24 HP lawn tractor Model #917.28870 that sounds fine, but BARELY moves forward. It does move in reverse a bit more easily. It feels like the parking brake is engaged when you...
It sounds like the brake plate is sticking on the transaxle,if you look on the right side of the transaxle a rod and spring run back from the front to a plate,under this plate are two 1/4 pins that actuate the brake pads on the disc,lubricate these pins with wd-40 and move the plate back and forth to see i this frees the problem up.
Jul 07, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
393 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
