Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer won't do its final drain-spin. It apparently made it through the wash cycles. I have tried re-setting, and using the drain-spin cycle several times. It does not proceed. The error message is F 7. what do I need to do? -- Thanks -- *J*
    Problem Solver:
  • 4 Answers
On the front of your washer below the door there is a removable panel. The screws are on the bottom of the washer. Take that panel off and inside you will find a Filter it is right in front. turn the cap counterclockwise and pull out the filter. Clean it up and reinsert it. They get full of pocket junk, hair, and coins. I warn you it smells horrid. Once you have it back together. Run a clean cycle for the machine and it should drain fine. If this doesn't work than it could be a problem with the control board.
Posted on Sep 27, 2010
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do I get my duet to drain and spin only. I do not want to rinse.
I have a Whirlpool Duet, though possibly a different model. I had the same question. I finally figured it out. On p. 14 of the manual, there is a section "To drain the washer manually". This says to select the RINSE/DRAIN & SPIN cycle and deselect the EXTRA RINSE option. In this case it cancels ALL rinsing for the cycle. This is how you get a spin-only cycle! Talk about idiotic, obscure user-interface design and bad manual writing!!! Didn't they think people would want clear instructions how to get a spin-only cycle?
If you have trouble with things being too wet after washing & needing an extra spin, you should try lowering the spin speed when you wash. This is what the BULKY setting does. If you have an unbalanced load, the washer cannot get up to the high spin speed the normal cycle calls for, and it is so dumb that it gives up and gives you a soaking wet load at the end instead.
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer, clothes dripping wet
set it for a drain/spin cycle and watch it 12 min. doesit sound like the pump is kicking on???? if so is it removing water??? (you should hear it or see it exiting out hte drain hose.) next is it actually spinning at full speed by min 7 in the display it should start ramping up to the final full rpm spins, usually faults out if there a problem with unit itself, otherwise its a user end issue. you ARE usinf HE detergent right? not just a little less of regular soap! although it sounds good HE detergent actually designed for yuse qith the frontloading products, too much suds causes , no hide speed spin aas well as a SUD in the display
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
