Question about Tag Heuer Kirium (CL1212.BA0705) Wristwatch
Tag cl111a-0. It has time date hands and numbers. It has t1. T2 m/d Can't adjust.
5 Suggested Answers
SOURCE: tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Posted on Jul 19, 2008
  • 4 Answers
SOURCE: can't set columbia CL-5009. Display is on T2, want T1
Try holding the st/st button while on time display
Posted on Mar 19, 2009
  • 93 Answers
SOURCE: Tag Heuer WK1110 Date Changing Problem
This could be caused by a couple of things. To fix this would require a qualified watchmaker to repair. The watch will need to be taken apart and the dial and hands will need to be removed to repair this problem.
Normally when we see this problem one of the wheels needs replacing. This can be caused by manually changing the date near midnight.
Let us know if we can help more.
Ken
Yellowstone Watch Inc.
Posted on Oct 05, 2009
gemineye61
  • 831 Answers
SOURCE: I need a manual for
http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf
Posted on Aug 23, 2010
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
Ferrari World Time watch setting, manual is awful and useless
You have to hold down B to set up T1 which is the time the hands will display. Once you see the City and T1 show up on the digital display you can go through the various settings to set time/date etc. Use B to cycle through setup and A to make the necessary changes.
Pushing the crown allows you to set up T2 or the time displayed on the digital section. You set this by choosing the time zone.
Hope this helps
Jan 05, 2015 | Ferrari FE-05-IPB-FC World Time Mens...
I can't set the time on my Adidas ADP6016 digital watch
There is two times possible in this watch ADP6016.
• Those times are named T1 and T2.
• IMPORTANT: When your displayed time is T2, you CAN NOT set the time but just set the offset of T2 relative to T1.
• You can see which time is displayed by looking for a very little T1 or T2 written just above the seconds
• To swap the displayed time from T2 to T1 (or contrary), you have to long press the start/stop button (top right white button)
• When your displayed time is T1, you CAN set the time with the solution given by soulgirljen
just before this one
Aug 29, 2012 | Adidas Digital Watch Adp6016
Need manual for Tag Heuer CL111A-0
I have the user manual in PDF file. If you still need it so I can email it to you.
Feb 11, 2012 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
Cl111A-0 manual
I have it in PDF file
if you still need it let me know
Oct 08, 2011 | Tag Heuer Formula 1 Alram WAC111A.BA0850...
Trying to seth the date on my Timex Indiglo CR1216
Jul 07, 2011 | Timex 40131 Wristwatch
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
May 14, 2009 | Diesel Digital Dz7069 watch
Can't set columbia CL-5009. Display is on T2, want T1
Mar 11, 2009 | Columbia All Sport Digital watch
Tag wk 1113-0
Position A:
Position B:
Position C:
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Setting watch
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
Hope this helps.
Nov 12, 2007 | Columbia All Sport Digital watch
Tag Heuer Kirium (CL1212.BA0705) Wristwatch Logo
241 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
