Question about RELIANCE ELECTRIC WATER HEATER
How do we know if our hot water heater is under warrenty?
  • 455 Answers
Hello,Look at the info sticker for a manuafactuer date/year.If it's less than 6yrs. the TANK is under warranty.
Posted on Sep 27, 2010
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add a comment as needed
Jun 02, 2013 | Water Heaters
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
How can i install my hot water heater model 71-408 b
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
Oct 25, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater fires and runs for 2 or 3 minutes and then cuts off.It tries to refire 2 or three times but wont .Red light inside comes on as if it is out of gas.I changed the T-stat and ECO and it still...
First of all, lets see if water is hot already by releasing pressure relief valve slightly and seeing if water is already hot.BE CAREFUL NOT TO SCALD YOURSELF! Shut water pressure off, first, but be aware it will still be under pressure at first.. Just hold a cup, or something under it and open it up slightly, or at least feel pressure relief valve to see if it feels warm/hot to touch. May just be by-pass not set properly in back of water heater. Let me know if hot from pressure relief at outside on heater.
Dec 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
My water is not getting hot
Under the top cover on the side of your water heater, cover's a thermostat that has a red reset button that may be tripped. Press it to reset.
If you have access to a wire tester to test electricity coming into water heater. Check your breaker box for a tripped breaker and power to element's..
Below is a link with information about water heater's that will be helpful to you.
http://www.water-heater-repair-guide.com/waterheaterthermostat.html
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Under sink water heater no flow of hot water from it
basically the principle of the heater is water flows into a internal tank and is heated by an element. You open a hot tap and the mains cold water forces the hot out and replaces it inside the heater.As you have a flow problem i can only suggest you may have some kind of restriction or blockage in the cold water supply at the water heater or from the hot supply from the heater.If you live in an area where lime content is high then this can calcify when heated.If you can, isolate the water supply and electrical supply and check the pipework for blockage.Also investigate your hot tap as this may be the fault. Good Luck
Mar 26, 2009 | Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
26 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
