Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
MY AEG FAVORIT SENSORLOGIC DISHWASHER DISPLAYS THE ERROR CODE .30. WHAT DOES THIS MEAN? HOW DO I RESET IT?
SOURCE: how do i fix error code 30?
I did like it was suggested and it functioned! Can't believe it. Actually I tipped the machine over, but not till the end (very slightly). It was a bit water on the ground. I removed it and put the machine upright. Thanks a lot!
Posted on Dec 31, 2007
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
SOURCE: My AEG favorit sensorlogic turbo
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
The dishwashers is coming up with an error code .30. What does this mean
its probably anti flood error and u might have a small leak somwhere
Jun 22, 2010 | AEG 24 in. Favorit 60870M Free-standing...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
Apr 26, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
728 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
