Question about Car Audio & Video
I have a background static noise coming from my speakers while in any mode. I own a 2006 Toyota Highlander hybrid. The static is kind of annoying and worse of all it carries over the bluetooth channel and makes conversations very difficult. any help would be great
SOURCE: Microsoft VX-6000 audio problem - static noise coming from speakers
i get a ground hum on audio. video ok
Posted on Oct 17, 2008
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
SOURCE: Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Posted on Jul 14, 2009
demonsm
  • 253 Answers
SOURCE: What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Posted on Jul 24, 2009
  • 1779 Answers
SOURCE: 2006 highlander hybrid limited owners manual download
The below site can provide a 'vehicle reference manual.' not the actual original owners manual. It is free, hope it has the info you need
http://qrg.toyotapartsandservice.com/
Posted on Dec 05, 2009
Testimonial: "Thanks for the replay.I could find the manual for 2006 Highlander and 2009 Highlander Hybrid.Is there a user manual for 2006 Highlander Hybrid Limited"
Toyota Highlander Hybrid 2008, Its switching on and coming on to Ready mode but never moves forward or backing . It happened twice. My mechanic changed Ignition coil sets all 6. still have problem
i think its not hardware problem can u check any alarm are symbol which is showing on ur display if its try to fix it .due to it was interlock until u not clear it ur machine will never move.
Oct 23, 2016 | 2008 Toyota Highlander Hybrid Limited
2006 Toyota Hybrid Highlander, Everything sounding and driving fine until pulled up to a drive thru line with foot still on brake, car seemed to start "missing" (old school) running rough, then a loud
this fan noise may be the coolant fan doing the job of cooling the radiator when there is no air flow through the radiator as in standing in a line or at lights. IN a drive through line you would have the window down and so the noise came to your attention when the fan cut in. However have it checked out by an accredited repair shop to put your mind at rest.
Mar 20, 2014 | 2006 Toyota Highlander Hybrid
How to change a thermostat in a 2006 Toyota Highlander Hybrid
follow the big pipe from radiaor to engien.
big pipe is connected with thermostat into engine
Sep 28, 2013 | 2006 Toyota Highlander Hybrid
I have a 2006 toyota highlander (not a hybrid). I am leaking transmission fluid and need to buy some. What kind do I need?
Automatic transmission today take a variety of fluids, not all the same. You need to look in your owners manual, if you don't have one a dealer will sell you the correct fluid. If the tranny is leaking I would have it fixed ASAP as just refilling it with fluid is not going to fix anything and could completely blow the tranny up. Don't be penny wise and pound foolish.
Mar 03, 2011 | 2006 Toyota Highlander
Changing the high-strip brake light in the Highlander rear door
take the inner pannel off and there will be two clips,screws ors bolts just simply remove theese and sisonect wiring it should just push inward and come right out.
Dec 30, 2009 | 2006 Toyota Highlander
Dec 05, 2009 | 2006 Toyota Highlander
TOYOTA HIGHLANDER HIBRID 2006
The ABS light stays on if there is a malfunction in the ABS system. If you DID get it turned off; & only by using a scan tool, it would come right back on if the vehicle has a definite malfunction.
Checking the Hybrid System: You def need a Toyota scan tool. No other way to check it.
Sep 21, 2008 | 2006 Toyota Highlander
Window buffeting noise- 06 highlander hybrid
not really,alot of vehicles have this resonating problem
Jul 29, 2008 | 2006 Toyota Highlander
Toyota Highlander Hybrid 2006
The hybrid battery is charged by the motor generator that is attached to the engine, and also charges during braking. Very sophistocated in how the hybrid battery gets charged.
That being said, you do NOT want to pull the battery out & attempt to charge it. There is no charger available anywhere to charge a hybrid battery. Toyota does not offer one, either. Hooking up a standard battery charger could cause disasterous results (it could explode). And, the possibility of getting shocked with over 300 volts DC is very good. When we have to handle hybrid batteries, we have to wear big, heavy rubber gloves so we do not get injured from the many contact points under the battery shell. This is not something you really want to fool with. The stakes are just too high. Sorry I was not giving you the info you are wanting, but, be safe & leave the battery alone.
Jul 21, 2008 | 2006 Toyota Highlander
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
