Question about GE Dishwashers
No power going to the water valve or the pump - the only thing working is the motor did replace the timer but didnot solve the problem checked all relays switches what wrong
    President:
  • 1,430 Answers
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Posted on Sep 27, 2010
  • GE Master
  • 3,247 Answers
Please provide the full model no. of your dishwasher.
It is possible the thermal fuse has blown. This could shut down the power to the timer and other devices. Need the model no. to be sure which part is affecting.
Dishwasher will not drain
Hello, Following things should be checked properly to see what actually the matter is.
1)Drain Hose It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again. 2)Pump Assembly The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective. Belt It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it. 3)Timer A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor. 4)Motor The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor. 5)Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them. Thanks
Jun 17, 2011 | Maytag Dishwashers
There is always over 2 inches of water remaining in tmy dishwahers
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
Sep 01, 2008 | Maytag Dishwashers
Water will not dain after washing
f the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Aug 05, 2008 | Whirlpool Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
dishwasher_pump-repair-kit.jpg Pump Assembly
dishwasher_belt.jpg Belt
dishwasher_timer.jpg Timer
dishwasher_motor.jpg Motor
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water will not drain out
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Belt
Motor
Timer
Jul 14, 2009 | Dishwashers
Not draining; about an inch of graywater in bottom. Dishes not clean. Unit is about 5 years old.
hi there. let me help you. check these things below and get back if we did not isolate the problem for you.
Drain line/air gap
Pump
Belt
Motor
Timer
May 28, 2009 | Bosch 24 in. SHX33A05 Stainless Steel...
My kenmore dishwasher will not drain completely. It seems to go thru all cycles, and leaves the bottom of unit covered with water. solve this
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 07, 2009 | Dishwashers
My new dishwasher wont drain.
hi there,
1. Drain line/air gap
2. Pump
3. Drain valve and/or solenoid
4. Belt
5. Motor
6. Timer
Drain line/air gap
Pump
Belt
Motor
Timer
problem is surely with one of the above so check and get going...
good luck
thanks for using FixYa
Jan 12, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag - MDB4800AWB - water will not drain
If water is not draining, check first that the drain hose is not obstructed. Try also advancing manually the timer/[programmer.
If water is still not draining, it may be a faulty drain pump, aproblem with belt/motor , or a defective timer/control panel.
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Belt
Motor
Timer
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon."
from The water doesn't drain from the machine
Sep 27, 2008 | Maytag 24 in. MDB4000 Built-in Dishwasher
Water in bottom of washer after fast cycle complete
Drain line/air gap
Pump
Belt
Motor
Timer
May 04, 2008 | Dishwashers
Dishwashers Logo
61 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
