Question about Sony Playstation 3 (PS3) Console
My playstation 3 will not switch on, the red power light is flashing and when i try to switch it on and eject the disc it flashes green on the power beeps then switches itself off.
    President:
  • 2,777 Answers
That is a very bad sign indeed. Does it ever at least eject the disc that is in there? Whenever you get this red flashing light it is equivalent to the Xbox 360's "red ring of death" meaning some hardware internally has failed. Try flipping the power switch on your PS3 (if your model has a power switch, it should at the back) and then unplug the power from the back of the PS3. Let it sit at least 2 minutes, then plug it in and flip that switch again. If it still powers on and blinks red you will need to contact Sony's PlayStation division for repairs:
Their number is 1-800-345-7669
Posted on Sep 27, 2010
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
SYSTEM DOES NOT TURN ON. FLASHES, SHUTS OFF, NO EJECT
Unfortunately, you are going to need to have your PS3 serviced by Sony. To eject your game, flip the power switch on the back of the PS3 to off. Then press and hold the eject button and turn the switch back to on again. This should eject the disc. Best of luck with the repair.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
Flashing red light
it would make a goooooooood trafic light
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 will light up green then yellow
1. Try turning the ps3 on and off and then hitting eject.
2. Do Not try to open up the playstation. You may do more damage than good.
3. Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBALive out of the playstation.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 problem
Heat Sync issue. CPU and GPU need re-seating as well. Email dwdpcrepair@gmail.com for more help
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
