Question about Panasonic DP-3030 Grayscale Copier
Light copies with panasonic 3030? Toner changed. Can't adjust to darker. Happens with copies and printing. Is there an adjustment that I can make?
  • 2072 Answers
SOURCE: Panasonic DP-150PA Light Copies to no copies
Have you reseated the drum and toner?
It can be a drum cartridge problem. have you tried that?
You say copy or print, so I am asuming this is multifunction and you do both printing and copying.
1, Have you shook up the toner cartridge well.
After the drum and shaking the toner, I would suspect the transfer assembly, Off hand I cant remember of that machine has a transfer roller, or if there is a channel where there is a hair fine wire running through it.
The wire may have broken, or if its a roller making poor contact.
The laser is also possible.The transfer will be on the right had door assembly.
Take the cartridges out and see if there is anything laying loose in the machine,
what you are describing sounds more like a drum or transfer problem.
sounds very much like a defective transfer. And again, could easily be the drum.
Did you have a jam just before this occured? If you had a jam in particular in the right hand door, you broke the transfer wire.
Yeah, i am rambling huh?
Posted on Apr 10, 2008
rockfixya
  • 679 Answers
SOURCE: Error code E000025-0000
1) Drum unitIs the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Good Luck
Posted on Feb 03, 2009
SOURCE: Dark copies in normal mode.
Cleaning the optics and corona wires will clean up your image quality. It's just dust build up on the mirrors and lens.
Posted on Apr 17, 2009
  • 100 Answers
SOURCE: COPIES FROM PANASONIC FP7722 ARE JUST BLOTCHY GRAY
yep!
we can say it is common error/malfunction for these series of fp-77xx
it is also called as quarc error
you may fix it by manually adding some toner at the developing unit
or by pressing USER PRESET + 11 + 1 to perform manual add toner maybe up to 5x until you see some improvement.
Posted on Mar 23, 2010
  • 5 Answers
SOURCE: copies are light
try shaking the toner bottle up, then putting it back in.
Posted on Apr 20, 2010
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
I have a Sharp AR M-165. If I try to do more than 20-30 continuous copies or prints I get a darkening of the top 40mm of the copied page which gets gradually darker and darker the more pages that are...
are u using a compatible toner or branded.this problem might be occurring due to toner .try to change the toner and developer .both at the same time because if u change the toner then the toner in developer module will get mixed with new one and u will have a problem
May 24, 2011 | Sharp Office Equipment & Supplies
Printed pages are light on both sides of page.
This is usually a sign that the toner cartridge is running low on toner. Replace the toner cartridge and see if the problem persists. If not, then problem solved.
If the problem persists, try adjusting the darkness settings in the printer settings when you are about to print. Sometimes even one notch darker can make a large difference.
Feb 28, 2011 | HP LaserJet 2430dtn Printer
The copies are very light. I have tried to adjust exposure, no change. I have already added toner. drum? fuser? Clean...what?
firstly clean the beneath the copyglass and clean the optics ( mirrors ), then try...
also try to darker the copy and see what happens, if its still light try to change the drum....
PS are you using the original Canon toner?
Nov 09, 2010 | Canon imageRUNNER 210S Copier
Brother HL-5502DN prints so light - can you adjust to make the print any darker?
Just wondering if you may have replaced the toner with a remanufactured unit.....it may be bad toner. or it may be ruinning low without warning you. I believe it is cartridge related whatever the case. recommend trying another one
You cannot adjust the contrast
Mar 09, 2009 | Brother HL 5250DN Laser Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Printing
Check the print quality setting on your computer when printing from printing preferences try quality. Also optionally you may want to consider reinstalling the driver,s and uninstalling the printer completely first, as this will restore it to defaul settings.
Jan 06, 2009 | HP LaserJet 3030 All-In-One Printer
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Panasonic DP-3030 Grayscale Copier Logo
63 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
