Kenmore washer 80 series model 20842990
Dear Tech Guru
My Kenmore washer overflowed the other day...Not sure at what point in cycle.
The only thing I noticed was the water level knob was just off the resting spot of the Medium load line....other than that it was just a usual load...Been watching it ever since and it seems fine. Could this be a fluke or should I not tempt the fates and raceout to get a new one. Purchased in 2000.. Small family use.
Thanks much
Elaine
  • 41 Answers
You answered your own question. It was in between the line and now it's fine.
Posted on May 23, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore 80 series washer wont spin
Sounds to me like you may have a lid switch bad. If you close the lid and don't hear that click then you can be sure that you have a bad lid switch. If it is bad your machine is thinking that your lid is up and so it won't do any washing or spinning. Replace the lid switch.
Apr 11, 2009 | Washing Machines
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
