Question about E-Machines eMachines Desktop PC
Zune I went into safe mode clicked on the Zune icon nada it just directed me to send a report to mcrosoft . Whe I did I received a message form ms stating that the crash I have experienced is a problem that thye donot have in their knon base .
    Champion:
  • 207 Answers
Do u get any type of error mesg ???
Posted on May 23, 2008
How do you replace the ignition switch on a 2002 buick century?
What do you mean no sound when turning key ? Does the car start an run ? Or the car doesn't crank ? Ignition switch's do not work the same way they did in the old days , especially on GM vehicles . The ignition switch is an input to the BCM - body control module , the BCM processes these inputs an then energizes relays to turn things on . Also sends messages to other modules for them to turn on or energize relays .
The power mode signal may be as simple as a B+ input wired to a particular ignition switch contact. If this is also the B+ supply to the module/device, the module/device will only operate with the ignition contact closed to B+. An example of this is the starter relay when it is wired directly to the CRANK/START contact of the ignition switch. When the CRANK/START contacts are closed, the starter relay is energized and provides a current source to the starter and starter solenoid. When the ignition switch leaves the CRANK/START position, the switch contacts open and the starter relay is de-energized. This removes the current source from the starter and solenoid and the starter operation stops.
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the Body Control Module (BCM). The BCM receives 4 signals/circuits from the ignition switch. These are the Ignition 0, Ignition 1, Crank and Accessory 1 ignition switch signals/circuits.
To determine the correct power mode the BCM uses:
The state of these signals/circuits, either switch closed (B+ = 1) or switch open (open = 0)
The sequence of switch closures received by the BCM
The status of the engine run flag.
Important: Any ignition switch states not covered in this table indicates a DTC setting situation.
The chart indicates the modes detected and transmitted by the BCM:
Power Mode Selected/Expected
Engine Run Flag Serial Data
Sampled Ignition Signal State
Power Mode State
Accessory
Ignition 0
Ignition 1
Crank
OFF-LOCK
0
0
0
0
0
OFF
Accessory
0
0
0
ACCESSORY
RAP
0
1 to 0
0
0
0
RAP
OFF-UNLOCK
0
0
0
UNLOCK
RAP
0
1 to 0
0
RAP-UNLOCK
Run
0
RUN
Crank
0
0
CRANK
Crank
CRANK
Run
RUN
Fail-safe Operation
Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the BCM fail to send a power mode message. The fail-safe plan covers modules with discrete ignition signal inputs as well as those modules using exclusively serial data control of power mode.
Serial Data Messages The modules that depend exclusively on serial data messages for power modes stay in the state dictated by the last valid BCM message until they can check for the engine run flag status on the serial data circuits. If the BCM fails, the modules monitor the serial data circuit for the engine run flag serial data. If the engine run flag serial data is True, indicating that the engine is running, the modules fail-safe to "RUN". In this state the modules and their subsystems can support all operator requirements. If the engine run flag serial data is False, indicating that the engine is not running, the modules fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
Discrete Ignition Signals Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid BCM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, B+, the modules will fail-safe to the "RUN" power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to "OFF-AWAKE". In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
You probably won't understand any of this info. your best but would be to take it to a qualified repair shop that has proper diagnostic test equipment !
Sep 29, 2016 | Buick Cars & Trucks
Not able to receive or send emails. No place on Screen for it!
Check your Junk folder
1. Sign in to Outlook.com account.
2. Click on Junk on the left pane.
3. Check to see if the missing mail is in this folder.
4. If you see any messages that should have been delivered to the Inbox, click the Not Junk.
Check your Blocked sender list
1. From your Inbox, click the cog icon.
2. Select More Mail Options .
3. Under "Preventing junk email", click Safe and blocked senders.
4. Click Blocked senders.
5. In the Blocked senders list, select the name or domain (the part of an e-mail address that follows the @ sign, such as outlook.com) that you want to receive emails from.
6. Click << Remove from list.
Add the email address to your Safe senders list
1. From your Inbox, click the cog icon .
4. Click Safe Senders.
5. In the text box, type in the email address or domain you'd like to always receive emails from.
6. Click Add to list >>.
Check your Email Rules
3. Click Rules for sorting new messages under "Customizing Outlook".
2. Perform one of the actions as per your requirement:
Click Edit next to the rule that you want to edit.
Or
Choose the rule that you want to delete and click Delete.
Note: Not all international characters are supported as filters.
Check your Junk Mail Settings
2. Select More Mail Options.
3. Under "Preventing junk email", click Filters and reporting.
3. Under "Choose a junk e-mail filter", choose the level of protection that you want, and then click Save. If the Exclusive level was set, all emails will go directly to your Junk folder except for messages from your contacts and email addresses that are in your safe senders, Outlook service announcements, and alerts that you signed for.
4. Click Save.
To go back to your inbox, click Outlook on the top left portion of the screen.
Check your Reply-to address
3. Under "Writing email", click Reply-to address.
2. Select the radion button beside Current e-mail address.
3. Click Save.
Thanks.
Hotmail Support
Sep 26, 2013 | hotmail.com
New account
You are not clear what is eject problems. Just i gas and share, i hope solved your problems.
Or
4. Click Save.
3. Click Save.
Thanks.
Hotmail Support
Sep 21, 2013 | hotmail.com
Facebook lottery
Hi Anonymous,
This is spam. For your privacy and security, do not send them any information about you. If you received this message via Facebook Messenger, you can click the gear icon and click Report. They will be reported as possible spam and eventually not be able to contact others.
Thanks
Mar 14, 2017 | Computers & Internet
Windows Error Reporting Error
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
I received an fake norton antivirus message stating that my computer was in trouble...blah, blah, blah... My virus checker reported a trojan. Afterwards...it reportedly had it contained. I decided t
In safe mode, your PC won't be able to use 3D programs so that's why it would be complaining about it on the screensaver.
Is this definitely showing "norton" as the virus scanner reporting the problem? Sometimes they have specific names that are massive giveaways when trying to find removal instructions for these fake AVs.
The best course of action when not knowing the exact malware that's been installed is to use MalwareBytes Anti-Malware, download this program onto the affected PC and let it do a full scan. It should resolve the issue for you.
The best way to download this is to use SAFE MODE WITH NETWORKING, not just regular safe mode.
There is a good guide, although fairly old, located here which will take you through the process.
Dec 23, 2012 | Toshiba Satellite C655S5085 Notebook
How do I send a picture with a SMS on a SGH-i780?
1) go into the menu
2) click messaging
3) click menu in the bottom right hand corner
4) click MMS options - this should bring up a screen with 5 tabs along the bottom of the screen (sending, recieving, profile, compose, about)
SENDING
priority : urgent
expiration : none
delivery time : immediately
message size : 300kb
hide address : unchecked
request delivery report : checked
request read report : unchecked
keep a copy : checked
RECEIVING
home network : auto download
roaming network : auto download
send delivery report : checked
send read report : checked
reject unknown sender : unchecked
advertisement allowed : unchecked
information allowed : checked
PROFILE
contract MMS
COMPOSE
MMS class : moderate imaging
creation mode : free
Jul 10, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Hibernation partition
What OS? xp? 98?
Have you tried loading last known good configuration?
What is the "whole process"?
Please report the exact error message you are getting, along with any stop error codes, and describe in a little more detail what's bringing it on, whether it's freezing up, etc.
If you're using xp, take a look at the event viewer logs to see what kind of errors or warnings are reported.
In the meantime, please take a look at MS KB articles here, here, here, here, here, and possibly here to see if they apply to your situation.
Try disabling hibernation, rebooting, then restarting. (control panel>power options)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 11, 2009 | NEC Versa SX Notebook
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
Zune
hmmm
pls check the same in safer mode is it working there?
i hope u know how to go ther!!!!
May 23, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
