Need to hook up heat - Heating & Cooling
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 28, 2010
Dishwasher not heating
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Mar 24, 2014 | Westinghouse SB915
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
I need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
May 07, 2009 | Honeywell Heating & Cooling
I have a Kenmore 70 series and it won't heat up when turned on. The dryer still tumbles but no heat. I just hooked this up could I have made an error in hook up? or is it needing me to buy soemthing to...
need you have to put the power cord on?you can also remove the back panel and check the heater box fuse on top of box(small fuse) and the heating coil on the lower side of heater box,you will have to take the twoo wire off to check it with your omns meter,let me know -mike
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Heat pump wiring
yes i can , you need to hookup the r and the o together so that the reversing vvalvce is allways energized . so with that im mind send r,y,c,o to theout side unit. at the ahu you'll hook up the 5 wires for the furnace, r g w1 w2 com and at the thermostat r,w1,w2,y,g,com,o then you will be set (the o get hooked up to o and goes straight out side.
Dec 03, 2008 | York Yankees Bedding MLB Comforter
Electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Jan 02, 2008 | Weather King 10AJA2501AH Air Conditioner
Edgestar Portable AC/Heater
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Dec 02, 2007 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
