Question about Lexmark C736DN Laser Printer
How do I find and replace 83.35 transfer module?
  • Official Brand Answer
  • 3,344 Answers
26d5How do I find and replace 83.35 transfer module? - 4a5dc6d.jpgass=
Contact Lexmark technical support (printer under warranty) or local authorized service provider for further assistance. Thanks.
Posted on Sep 27, 2010
How do you change out 4 wheel drive switch on 2004 Yukon
Before trying to replace the switch ,are any lights flashing ? 2hi , 4lo, 4hi etc... Do you know which transfer case yours has ?
Transfer Case - BW 4482-NR4
Transfer Case - NVG 246-NP8
How many buttons ?
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel
Before you replace the switch and finding out that it isn't the problem . The switch is a low voltage input to the tansfer case shift control module (A COMPUTER ) Could have diagnostic trouble codes stored .
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0329
DTC C0359
DTC C0550
Auto part stores can not read these codes .
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria have been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly. In addition, the switch includes a VSES request button which sends a voltage signal to the transfer case shift control module. The transfer case shift control module in turn sends a request via the class 2 data bus to the ABS control module which controls the VSES system.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel. When the ignition key is in the RUN position, the transfer case shift control module monitors the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria has been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly.
DTC B2725
Circuit Description
The range/mode switch circuit consists of 5 modes. The transfer case shift control module supplies 5 volts to the switch through the 5 volt reference circuit. The current travel through the resistor of the currently active mode. The current is then returned to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit.
When each of the modes are selected they complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch input to determine whether the Neutral, AWD, 2HI, 4HI, or 4LO mode was selected by the driver.
You may want to take this to a repair shop .
Jul 28, 2017 | Cars & Trucks
1998 chevy blazer four wheel drive not engageing
You replaced all those parts without knowing what is wrong , you like making parts stores rich ? Did you have it checked for DTC'S - diagnostic trouble codes ?
Transfer Case Control Module Description
The TCCM performs the following functions:
• Receives input signals
• Processes the signal information
• Develops output signals
• Sends the output signal in order to control the shifting of the transfer case
The TCCM receives input signals from the following sources:
• The transfer case shift select buttons
• The NSBU switch on the vehicles with automatic transmissions
• The clutch position switch on the vehicles with manual transmissions
• The vehicle sped sensor calibrator module
• The encoder/motor range and the mode feedback signals
• The diagnostic enable
• The front axle mechanical status signal
In order to ensure the electronic shift system is operating properly, the transfer case control module (TCCM) continually performs diagnostics checks on itself and other parts of the electronic shift system when the ignition switch is in the run position. The following are different types of system checks that the TCCM continually performs.
Motor and Relay Voltage Checks
Whenever the electric-shift motor is turned ON or OFF the motor and the electrical circuits are tested both in the de-energized and energized condition. If one or both voltage relays fail to detect the proper voltage after energizing or de-energized and energized condition. If one or both of the voltage relays fail to detect the proper voltage after energizing or de-energizing, the shift is aborted by the TCCM and a DTC of 3 is stored in order to indicate a faulty TCCM motor circuit.
If one or both relays fail to detect the proper voltage after de-energizing, both relays are turned ON by the TCCM, (even with the ignition switch positioned OFF) in order to prevent the motor from running. The TCCM then stores a DTC of 3 in order to indicate a faulty TCCM motor circuit. All of the status lamps blink three times, stop, and repeat the blinking continuously in order to alert the driver that the electronic shift system requires immediate repair. The battery will drain when this condition occurs, regardless of the ignition switch position.
DTC 001
DTC 002
DTC 003
DTC 004
DTC 001
The transfer case shift control module normally has battery voltage supplied to it at all times through the battery positive voltage circuit (CKT 40). When the ignition is ON, the transfer case shift control module conducts a self-test to determine if it retains the same memory it had when the ignition was last turned OFF. This self-test indicates whether the RAM standby power supply to the transfer case shift control module pin C6 was interrupted, which would result in clearing DTC's from memory. If the self-test fails the transfer case shift control module sets DTC 1.
Inspect the CTSY LP fuse for an open.
DTC 002
The transfer case encoder motor is an assembly which houses four separate channels. These channels are used to indicate to the transfer case shift control module the present gear position of the transfer case or if the transfer case is in transition between gears. The encoder motor assembly consists of an electronically conductive inner ground ring in contact with a three legged wiper arm. Each leg's length is such that it makes contact with the conductive regions of the four channels. When any leg of the wiper arm is making contact with the conductive area of any channel, the encoder provides a path to ground to the inner ground ring.
During electronic shifting, the transfer case shift control module monitors the transfer case encoder circuit for the proper operating sequence. If at any time during a shift, the encoder changes from one position to any position other than the next possible position, an error counter in the transfer case shift control module increments by four. After the counter reaches 32, the transfer case shift control module set a DTC 2, a permanent "encoder fault," and reverts to a 2HI to 4LO or a 4LO to 2HI shift pattern only. To guard against a transient, random encoder fault due to vibration, dirt, electrical noise, etc., the fault counter reduces by one each time the transfer case shift control module detects a valid encoder value. The encoder must intermittently fail 25 percent of the time for the transfer case shift control module to consider it faulty and store DTC 2.
DTC 003
Circuit Description
The transfer case encoder motor has a bi-directional, permanent magnet, D.C. motor. When energized, (through Motor Control A or Motor Control B, the ground is provided by the opposing motor control circuit and then grounded through the transfer case shift control module ground circuit), the motor, through a series of gears, rotates a shaft which moves the mode and range forks to shift the transfer case between 4H, 2HI, and 4L ranges.
This DTC detects a short or open in the battery positive voltage circuit (CKT 1640), ground circuit, an internal short in the motor windings and related circuitry, or an internal transfer case shift control module failure.
Action Taken When the DTC Sets
In the event that one of the motor control circuits is energized (battery voltage is applied) the transfer case shift control module will energize the other motor control circuit to keep the motor from running. All switch indicator lamps will flash continuously to prompt the driver that service is required. The transfer case system will be disabled and the transfer case shift control module will remain energized even with the ignition in the OFF position.
Conditions for Clearing the DTC
The condition for setting the DTC is no longer present and a momentary loss of battery power at the battery positive voltage circuit (CKT 40).
Diagnostic Aids
When the vehicle is equipped with a manual transmission the clutch pedal must be depressed and working correctly in order for the transfer case to shift to the 4 low position. In order to confirm that it is operating correctly go the engine data 1 screen under the engine data display and observe the clutch pedal switch parameter.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests the battery positive voltage circuit (CKT 1640) for an open or high resistance.
This step inspects the ATC fuse for an open.
This step tests the ground circuit.
This step tests the Motor Control A and B circuits.
DTC 3 -- TCCM Motor Circuit Step
Action
Value(s)
Yes
No
Important: Check the transfer case shift control module for DTCs. The transfer case shift control module is not a class 2 device. DTCs are displayed on the transfer case shift control switch. Use the following four steps to obtain DTCs.
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes.
Did you perform A Diagnostic System Check - Transfer Case?
Go to Step 2
Go to Diagnostic System Check
Backprobe and measure battery positive voltage (CKT 1640) at the transfer case shift control module.
Does the voltage measure near the specified value?
B+
Go to Step 6
Go to Step 3
Inspect the ATC Fuse 20A.
Is the fuse blown?
Go to Step 5
Go to Step 4
Repair the battery positive voltage circuit (CKT 1640) for an open or high resistance. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 11
5
Repair the battery positive voltage circuit (CKT 1640) for a short to voltage or short to ground. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Replace the ATC Fuse.
Go to Step 11
6
Connect a test lamp from the battery positive voltage circuit (CKT 1640) to the ground circuit at the transfer case shift control module.
Does the test lamp illuminate?
Go to Step 8
Go to Step 7
7
Repair the ground circuit for an open or high resistance. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Go to Step 11
8
Backprobe and measure voltage at the transfer case shift control module between the transfer case motor control A circuit and the transfer case motor control B circuit.
Press the 4HI then 4LO on the shift control switch.
The DMM should read +12V in one direction and -12V in the other direction.
+12V/-12V
Go to Step 9
Go to Step 10
9
Repair the open or high resistance in the transfer case motor control A or B circuits. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems. If OK, replace the transfer case encoder motor. Refer to Motor/Encoder Replacement .
Go to Step 11
10
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
Did you complete the replacement?
Go to Step 11
11
Clear all DTCs from memory. Refer to Diagnostic Trouble Code (DTC) Clearing .
Operate the vehicle while pressing each of the buttons on the transfer case shift control switch.
Does the DTC reset?
Go to Step 2
System OK
There is a bit more to it then just replacing parts ! Your best bet - Take it to a qualified repair shop .
Feb 07, 2017 | Chevrolet Blazer Cars & Trucks
I own a 02 foard explorer shift motor was bad i think and i removed it, i started it to relocate it, installed the new shift motor
Don's 1999 Ford Ranger shift motor PROBLEM SOLVED ...
? 13:05
https://www.youtube.com/watch?v=wcn39gwPWfI
Oct 1, 2013 - Uploaded by gtarman49
Don's 1999 Ford Ranger shift motor PROBLEM SOLVED. ...How to find replace fix 4x4 transfer case shift module 2002 Ford Explorer 4 wheel ...
How To Install Replace 4x4 Transfer Case Shift Motor Ford ...
? 9:15
https://www.youtube.com/watch?v=9ldrtZODxQ8
Oct 26, 2010 - Uploaded by 1A Auto Parts
How To Install Replace 4x4 Transfer Case Shift Motor Ford Explorer .... transfer case shift module 2002 Ford Explorer 4 wheel drive not working ...
How to find replace fix 4x4 transfer case shift module 2002 ...
? 3:07
https://www.youtube.com/watch?v=sZw3SS2Pt-4
Nov 3, 2013 - Uploaded by kirk colombo
... transfer case shift module 2002 Ford Explorer 4 wheel drivenot working ..... I replaced the transfer motor so i think it is the control module.
Jan 08, 2016 | Cars & Trucks
Service awd light comes on and off awd doesn't work when light is on
You need to check wiring an connectors at the transfer case shift control module an check power an grounds at the module ! If all seams good there a scan tool will need to be hooked up to check for codes ! If none of this makes no sense or you don't under stand any of this you need to take it to someone who does !
Was the Transfer Case Diagnostic System Check performed?
Go to Step 2
Go to Transfer Case Diagnostic System Check
  1. Install the Scan Tool .
  2. Turn the ignition ON, engine OFF.
  3. Use a Scan Tool in order to command the SERVICE indicator (AWD/4WD) lamp OFF.
Does the SERVICE indicator (AWD/4WD) lamp turn off?
Go to Step 3
Go to Step 4
Is the repair complete?
Replace the instrument cluster. Refer to Instrument Cluster Replacement in Instrument Panel.
Go to Step 5
Feb 23, 2015 | 1999 Oldsmobile Bravada
Stuck in 4 wheel Drive High but no lights are lit
Hi Jimi , There are very specific diagnostic procedures to follow for diagnosing this system. First a good visual inspection of the transfer case an fluid level an wiring connections. The transfer case shift control module is equipped with the ability to store diagnostic information, which is useful to a technician in the event of module, component or wiring failures. This information can be retrieved from the transfer case shift control module by way of flash codes, which are displayed on the three transfer case shift control switch buttons. These buttons are located on the instrument panel to the right of the steering wheel Before obtaining DTCs, perform the following transfer case control module (TCCM) Self-Test.
TCCM Self-Test
  1. Observe the transfer case shift control switch indicators while turning the ignition switch to RUN. A properly operating system will flash all indicators and then will return to the current gear. If the system is operating normally, then proceed to Displaying Codes.
  2. If the TCCM failed the Self-Test, then test the following circuits.
  3. ?€¢
    Battery Positive Voltage (40 and 1640), and Ignition 3 Voltage for battery voltage
    Ground Circuit for ground
    Diagnostic enable circuit for an open or high resistance
    Transfer case shift control switch connector
  4. If the above circuits are normal but the TCCM still fails the Self-Test, replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
DTC Displaying
  1. Turn OFF the ignition for 10 seconds.
  2. Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
  3. Turn ON the ignition, with the engine OFF.
  4. Observe the transfer case shift control switch select buttons for flashing codes. Refer to Diagnostic Trouble Code (DTC) List .
Important: If the transfer case shift control switch buttons all blink only once and then stop, no fault codes are stored in the transfer case shift control module.
When one DTC is stored in memory, that code will blink that number of times followed by a 3 second pause and then repeat.
If more than one code is stored, the first code will blink, followed by a 3 second pause and then the second code will blink.
This sequence will continue until PIN 13 on the DLC is no longer grounded.
If the TCCM will not communicate the presence or absence of DTCs, test the above circuits in Self-Test Step 2. If the circuits are complete, then replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
Let me know if you have any codes , I have code definitions an procedures.
Feb 04, 2015 | 2003 GMC Sonoma Extended Cab
I have a 1998 Chevy Tahoe I tryed to put my truck is 4wd low and it tryed and keep on blinking and went back to 2wd and blow a fuse and I tryed again and did it again but then the the service 4wd light...
Which 4X4 system does your tahoe have ?
Transfer Case System Description (Selectable 4WD)
The New Venture Gear Model NV243 is an electronically controlled optional transfer case for use on four wheel drive K trucks. The driver selects 2HI, 4HI, or 4LO by pushing one of three illuminating shift select buttons mounted on the instrument panel. The shift select buttons display the transfer case mode and range, self-test, diagnostic trouble codes, and electronic shift mechanical engaging problems.
Transfer Case System Description (Automatic 4WD)
The two speed Auto transfer case system utilizes a part time front axle. The system allows the driver to select the transfer case position with a touch of a button. The following positions can be selected: 4-wheel drive high range (4H), All Wheel Drive (AUTO), 2 Wheel Drive high range (2H), Neutral (N), and 4-Wheel Drive low range (4L).
The Auto Transfer Case (ATC) Control Module controls all the shifting action of the transfer case based on input from the driver as well as information from the Vehicle Control Module (VCM) /Powertrain Control Module (PCM).
4WD (4H or 4L) mode: This is accomplished by engaging the front axle, applying PWM to an electric motor to apply maximum torque, (fully compressing the transfer case clutch plates) to the front axle, then removing the ground on circuit 1569, thus locking the motor in position and stop the PWM to the motor.
AUTO mode: When in this mode of operation, the system should engage the front axle, then it monitors the front and rear propshaft speeds for any speed differences. When the system senses rear wheel slip, a difference of propshaft speed between front and rear, the Auto Transfer Case (ATC) Control Module will use pulse width modulation (PWM) to drive an electric motor. This motor transfers only the required torque to the front wheels to gain additional traction on slippery surfaces up to 75 mph. There is no torque applied to the front wheels until the module senses rear wheel slip.
Throttle anticipation (only operational when in AUTO mode): If the vehicle is below 5 mph and the accelerator is pressed quickly beyond a set point, the system will automatically transfer a percentage of torque to the front wheels to help prevent the rear wheels from slipping, as in a hard acceleration from a stopped position.
The Auto Transfer Case (ATC) Control Module also has the capability of engaging the front axle while the vehicle is in motion. It does this by applying PWM to the electric motor to apply torque to the front axle, this action is used to match the speed of the front and rear propshafts. After the module senses the proper speed, it then supplies a ground on circuit 1570 to engage the front axle.
The Auto Transfer Case (ATC) Control Module will accept a mode shift only when the engine is running and a valid Motor/Encoder signal is present. A mode shift is any shift between 2H, 4H, and AUTO.
The Auto Transfer Case (ATC) Control Module will permit a range shift only if the following conditions are met within 30 seconds of the request:
Automatic 4WD Diagnostic Aids
A Scan Tool reads and displays the following information:
• Diagnostic Trouble code(s)
• Code status bit (are codes set or not)
• Transfer case lock status
• Lamp in the switch/lamp assembly
• Motor/Encoder gear position
• Ignition (3) voltage
• Front propshaft speed sensor (KPH)
• Front axle switch (open/closed)
• Front axle requested position (engaged/disengaged)
• Rear propshaft speed sensor (KPH)
• Mode switch position request
• Park switch (open/closed)
• 4WD (Adapt) Mode Auto bit
• Current Mode corrective action PWM
• Average and highest PWM applied during last slip recovery event
• Throttle anticipation mode
• Average and highest PWM applied during last Throttle anticipation corrective action event
• Difference between front and rear propshaft RPM
• Adapt event counter
• Throttle position sensor percentage
Check the transfer case shift control module for DTC's. The transfer case shift control module is not a class 2 device. DTC's are displayed on the transfer case shift control switch. Refer to Diagnostic Trouble Code (DTC) Displaying .
Are any DTC's present?
TCCM Self-Test
• Battery Positive Voltage (40 and 1640), and Ignition 3 Voltage for battery voltage
• Ground Circuit for ground
• Diagnostic enable circuit for an open or high resistance
• Transfer case shift control switch connector
DTC Displaying
• When one DTC is stored in memory, that code will blink that number of times followed by a 3 second pause and then repeat.
• If more than one code is stored, the first code will blink, followed by a 3 second pause and then the second code will blink.
• This sequence will continue until PIN 13 on the DLC is no longer grounded.
• If the TCCM will not communicate the presence or absence of DTCs, test the above circuits in Self-Test Step 2. If the circuits are complete, then replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
Apr 15, 2017 | Cars & Trucks
2004 RA 4wd push button. It was selecting 4x by itself. The actuator on the transfer case has been replaced. Operated as it should for some months and fault returned. The dealer mechanic was unable to...
There was a revised Transfer Case Control Module for this lock up condition that affected up to August 2003 built & VIN # MPATFS77H4H510581,possibly your vehicle, part number 8973684490 is the newer revised one. Before replacing module they should have checked the limit switches on side of transfer case, gear box and dont forget the one on the front axle, for loss of continuity. A Dealer (Tech Line) TL0950-0509 is a full updated diagnosis tip flow chart to use. If you want a copy I can E-Mail.
Feb 24, 2011 | Isuzu Rodeo Cars & Trucks
2000 jimmy cant turn 4 wheel drive on pushed thev button n light keeps on flashing n 4 wheel drive
The simple answer is to replace the TCCM (transfer case control module).
Being both cheap and inquisitive, I wanted to investigate further, and I will provide a more in-depth answer.
This answer pertains to various GM vehicles. These include the Chevy Blazer, GMC Jimmy, S10, S15, Sonoma vehicles from 1999, 2000, 2001, 2002, 2003, 2004, & 2005.
Specifically the 15748800 module for the NP8 option 4 button automatic 4X4 NVG-236/246 transfer case.
I doing research online, I find that 15154323 might be an alternate TCCM, and that GM redesigned the module and now sells the replacement for this module with a 12577412 part number for about $300.
This information refers to the 15748800 module.
2000-jimmy-turn-4-bqqpoqfgk1hfvr1c2liydaq2-3-0.jpg Symptoms. If the vehicle is started and driven in 2 hi, the vehicle operates normally.
If the driver attempts to switch the transfer case into any other mode, the transfer case makes noise as it shifts, the service 4x4 light comes on and the newly selected mode indicator light starts to flash.
2000-jimmy-turn-4-bqqpoqfgk1hfvr1c2liydaq2-3-2.jpg The TCCM is mounted behind the passenger side kick panel cover. It should be removed but left connected. Pin F4 should be monitored with either a lamp or meter. This pin should be high or 12 volts when in 2 wheel drive, and low or ground when in 4 wheel drive.
A quick test of the system is to ground the F4 pin, recycle the ignition, and try shifting the transfer case into and out of 4 wheel drive. ( I used a lamp based test light to be safe. Do not an LED based one.) If the mode indicator light remains steady and the Service 4X4 does not light, proceed with this repair procedure. If this does not resolve the issue, please proceed to troubleshoot the front vacuum system, 4X4 solenoid, 4X4 actuator, front axle, or front axle indicator switch.
If this test appears to resolve the issue, you will need to remove the TCCM module from the vehicle. Bend the 8 tabs away from the back cover. Remove the top cover, unscrew the board from the back cover / plate. turn over the board at a static safe work station, and measure the indicated 10,000 ohm SMD resistor. In this module, the resistor is required to operate near it's limits, and I believe that the conformal coating trapped heat and caused the resistor to fail. You can check other resistors nearby for a relative comparison. If found to be open, the resistor can be replaced with a higher power value 10,000 ohm SMD resistor, or a conventional 10,000 ohm resistor with wired leads.
The TCCM should be checked for corrosion on the connectors and cleaned if nessacary. The module can then be restored to the vehicle, and your 4X4 should work normally.
Please respond if this procedure helps you.
2000-jimmy-turn-4-bqqpoqfgk1hfvr1c2liydaq2-3-5.png Front view / pin side
f16f1 Connector Part Information1205210716 Way F Micro-Pack 100 Series (ORN) Pin Wire Color Circuit No. Function
E1 Tan 1569 Transfer Case Lock Soleniod Output
E2 - - Not Used
E3 PNK 1561 AWD/4WD Indicator Lamp Output
E4 Lt GRN/BLK 1563 2 HI Indicator Lamp Output
E5 BRN/WHT 1555 Transfer Case Position Switch Encoder Signal
E6 RED/WHT 1556 Transfer Case Position Switch Encoder Signal
E7 YEL/BLK 1558 Transfer Case Position Switch Encoder Signal
E8 DK BLU/WHT 1557 Transfer Case Position Switch Encoder Signal
E9 DK GRN/WHT 1133 Class 2 Serial Data Signal
E10 BRN 241 Fuse Output - Ignition 3 - Type III Fuse
E11 PPL 806 Fuse Output - Crank - Type III Fuse
E12 YEL 400 Vehicle Speed Sensor Signal
E13 PPL 401 Vehicle Speed Sensor Return
E14 BLK/WHT 1695 Four Wheel Drive Front Wheel Lock Telltale
E15 - - Not Used
E16 BLK/WHT 451 Engine Control Module Ground
F1 PPL/WHT 1565 4 LO Indicator Lamp Output
F2 TAN/BLK 1566 4 HI Indicator Lamp Output
F3 BRN 1560 Neutral Indicator Lamp Output
F4 GRA/BLK 1570 Front Axle Actuator Output
F5 LT BLU 2221 Vehicle Speed Sensor Signal
F6 DK GRN 2222 Vehicle Speed Sensor Return
F7 GRA/BLK 1694 Four Wheel Drive Switch Signal - Low
F8 - F11 - - Not Used
F12 BLK/WHT 1554 Transfer Case Encoder Signal Return
F13 LT GRN/BLK 431 Reference Voltage Feed - 8 Volt Reference
F14 LT GRN/BLK 431 Reference Voltage Feed - 8 Volt Reference
F15 - - Not Used
F16 LT BLU 1693 Four Wheel Drive Switch Signal
2000-jimmy-turn-4-bqqpoqfgk1hfvr1c2liydaq2-3-9.png Front view / pin side
Connector Part Information120528564 Way F Metri-Pack 280 Series (BLK) Pin Wire Color Circuit No. Function
A BLK 1552 Transfer Case Motor Feed - Clockwise
B RED 1553 Transfer Case Motor Feed - Counterclockwise
C BLK 1050 Ground
D ORG 1640 Fuse Output - Battery - Type III Fuse
Jan 28, 2011 | 2000 GMC Jimmy
I have a 97 Chevy blazer with push button 4 wheel drive and it don't shift In to 4 low or 4 hi and the light should flash for 30 second then go back to 2 hi if it can't shift but when you push the button...
How about to the switch , is there battery power ? Fuse #15 FWD 10amp. I/P fuse panel . BCM - body control module light's the switch indicators 2hi, 4hi,4low . Check fuse #6 10amp I/P fuse panel .
DTC 002
Test Description
This step measures the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
This step tests the suspect circuit(s) for an open, short to power, or short to ground.
This step tests the encoder signal ground circuit for an open or high resistance.
DTC 2 -- Encoder Fault Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Did you perform the Diagnostic System Check - Transfer Case?
YES - Go to Step 2
NO - Go to Diagnostic System Check
Disconnect the connector at the encoder motor.
Measure the voltage between the transfer case encoder circuit channels P, A, B, and C to ground.
4.8-5.1 V
YES - Go to Step 4
NO --Go to Step 3
Test the suspect circuit for an open, short to power, or short to ground. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 8
NO - Go to Step 7
Turn the ignition switch OFF.
Test the encoder signal ground circuit for an open or high resistance. Refer to General Electrical Diagnosis and Wiring Repairs in Wiring Systems.
YES - Go to Step 8
NO - Go to Step 5
5
With a DMM at the transfer case module connector probe the encoder sign ground pin and ensure a good ground path through the module.
Did the DMM indicate a good ground path?
YES - Go to Step 6
NO - Go to Step 7
6
Replace the transfer case encoder motor. Refer to Motor/Encoder Replacement .
YES - Did you complete the replacement?
NO - Go to Step 8
7
NO - Go to Step 8
8
Does the DTC reset?
YES - Go to Step 2
NO - System OK
Aug 29, 2017 | 1997 Chevrolet Blazer
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Lexmark C736DN Laser Printer Logo
3,585 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
