Question about Health & Beauty
Error code 4171 in CR 30 -x DI 5302 , X-ray digital radiography system.
4 Suggested Answers
SOURCE: Have phillips modle RC144 5302 remote for verizon
I'll tell you that guy is a **** for FREE!!!
Posted on Oct 23, 2009
  • 23 Answers
SOURCE: system is fuji computed radiography.
Unfortunately I'm going to have to say try to find someone in the field to assist with this type of equipment. Equipment like that isn't a simple desktop system typically. I highly doubt people in this general computer purpose would be able to help install let alone troubleshoot the problems your likely to run into.
I am really sorry i'm unable to help but I think it's best to leave this time of equipment to professionals in the specific field itself.
Posted on Dec 21, 2009
SOURCE: NEED REMOTE CODE
Go on the Verizon website and request a new remote, the Verizon P265 Remote model. It will have all the newest firmware and it should have the code. I know this because I had a TCL 32" TV and the code wasn't on my old Philips RC 1445302 model. TV and new remote are "talking" just fine now. Verizon won't even want the old one back.
Posted on Dec 29, 2010
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
O2 sensor
the 02 sensors are in the exhaust system, screwed into exhaust like a spark plug. it is your upstream sensor. to change the sensors, first remove the wire to it, get a 02 sensor socket from the auto parts store. use the rachet and socket to take it out. good-day !
Apr 17, 2012 | 2003 Honda CR-V
Have a Phillips RC144 5302 Remote that is not working with a LG 372D Flat screen TV
Try these codes.
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 08, 2012 | Televison & Video
Bilog ako nakikita sa cr, hinahanap hanap din sa library, di pwedeng upuan pero puwedeng higaan. kitang kita sa gabi nakatago pag araw.
general term na:FOAM..bilog ang styrofoam,sponge ay makikita sa cr,hinahanap sa library ang meaning ng foam ng mga estudyante,di sya puwedeng upuan kasi lulundo sya,dinesign ang bedfoam para higaan..distributed ang bigat kapag nakahiga,gamit sya sa pagtulog kaya kita sya, pero nililigpit kapag araw...parang banig
Sep 25, 2011 | Computers & Internet
Canon 400D I have an error code Err01 I have cleaned contacts between the camera and lens but still have the error code
I had the Error 01 message on my 400D
I changed the support battery ( CR 2016 3 V) which is placed inside the main battery compartment.
This did the trick.
Jan 18, 2010 | Canon EOS 40D Digital Camera
System is fuji computed radiography. now want to install the cr console soft ware for which 3 cds are provided by the comany. machine detail--FCR XG-1,SERIAL NO--56633750B,CR-IR 346RU
Dec 18, 2009 | Computers & Internet
HELP
Hi Joanna,
I have extensive experience working in dental digital radiography so I may be able to offer some assistance. First your state you are running Inspiron Vista Windows XP, please help me sort that out.
Inspiron is a model line from Dell, there are 500+ models and every one is different, please tell me the full model# on the bottom, better yet the express service code then I can look up the exact hardware specification. Second, what version of windows are you running? Windows Vista(Home Basic, Home Premium, Business or Ultimate), or XP(Home, Pro, Media Center)?
Then please provide some useful info about your MRI's. What program do you use to view them, do they come on a CD/DVD with the program installed or did you recieve a seperate disk/download for the program?
With this info in hand and a description of the problem, eg/ Not a clue how to start, or, loaded X program get Y error message when I open an image, I can at least ascertain your problem and make some suggestions.
Unfortunately the one liner request you fired at us just doesn't give me enough to work with, imagine I told you about my daughter Anya who is missing 60% of her Corpus collosum(She really is, true story)...then asked you to diagnose why, and what effect it might have on her life and you'll know how hard it would be for me to answer your question without this info.
Hope to hear back from you soon as I enjoy radiography and MRI challenges,
Chris
Jul 01, 2009 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Jun 21, 2009 | Philips Televison & Video
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Health & Beauty Logo
156 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
