Question about Siemens SX66
Screen says USB or Serial on top and v2. 07 at the bottom
  • 102 Answers
Open the Back Cover.. remove the Battery, Simcard, Memory Card and then leave it open for 1 minute.
Put the battery back, start your device then if you get the same message you need to update the firmware...
In the worst scenarios, your Siemens SX66 has a corrupt ROM and need to be fixed as in "Hardware"... which can be done by a Siemes expert.
Good Luck
Posted on May 24, 2008
Serial # is W86161RLVJ3. What kind of USB installed?
Click on the Apple in the top left corner of the screen.
Then click on "About this Mac"
Then click on "System Report"
On the left side of that screen just above Network, you should see USB. Clicking on it should bring up a full report on your USB.
Oct 09, 2015 | Apple MacBook Pro with 17" Display
WHERE IN WINDOWS EXPLORER IS Kingwin Usb 2.0
it should show under My Computer.
Click on the start icon at the bottom left of screen, and on the right of that panel you should find My Computer. Click on that and Windows Explorer will open showing the disks and and folders available to you (at the top level). It should be there, maybe only shown as 'USB Device' or something like that, without the words 'KingWin'. If it's not there, you need to try some more involved steps. Please report if you still encounter problems
(what is your computer and O/S ?)
Aug 24, 2014 | Kingwin DM-2535U 2.5? / 3.5? SATA Single...
Model is Satellite P105 S6024, serial # 86019106W About one inch from right-hand side of screen, a 'white line' (in appearance) has appeared. It is about one inch in width, and goes from top to bottom of...
When you get vertical lines from the top of the screen to the bottom of the screen, it means you have bad LCD panel, you need the new one. It will get worst with more lines as time goes by.
Mar 04, 2010 | Toshiba Satellite P105-S6024 Notebook
Upgrades for hp pavillion 533 such memory
This is everything I could find on your computer.
Base processor and speed Celeron 2.0 GHz
  • 400 MHz Front side
  • Socket mPGA478
Back to top Chipset 845GL Back to top Motherboard manufacturer
  • Manufacturer for computer serial numbers starting with KR and CH: Trigem Glendale
  • Motherboard for computer serial numbers starting with MX: ASUS IT8708F NOTE: The serial number can be found printed on the back of the HP Pavilion computer, or while holding down the Ctrl and Altkeyboardkeys, press S. A screen will pop up with the serial number.
Back to top Memory Component Attributes RAM (installed)
Allocated to Video 256 / 2100 DDR
Up to 64MB Maximum allowed 1 GB (requires replacement of the installed 256 DIMM) Speed supported PC2100 / PC1600 Type DDR SDRAM DIMM slots Two Open slots One Back to top Hard drive 60GB Ultra DMA Back to top DVD-ROM/CD-RW combo drive 16x/8x/8x/40x maximum speed Back to top Diskette drive 1.44 MB (3.5-inch) Back to top Fax and data modem Cheetah 2 V.92 Modem Back to top Video graphics Integrated Intel Extreme Graphics with up to 64MB shared memory Back to top Sound/audio Integrated AC97 audio Back to top USB specification USB 2.0 Back to top Network Integrated on motherboard: 10/100Base-T LAN interface
Dec 26, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Hi i have an acer aspire an my mouse has just froze on the middle of my screen i cannot figure out why please help
Here's a few troubleshooting steps. If it's a USB mouse, unplug it and plug it back in. If serial, reboot the PC. You can also unplug the USB mouse and try a different port. Try plugging in a different mouse as well.
Finally, hit CTL+ALT+DEL and check your applications tab to see if any program is not responding. Check Processes to see if anything is eating up your CPU. Do this by clicking on CPU once, then again. The most processor intense programs will be at top. If so, you may choose End Process at the bottom.
Jan 14, 2009 | Computers & Internet
Cant connect to pc
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 07, 2008 | Samsung YP-U3 MP3 Player
Can't reset
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
May 23, 2008 | Siemens SX66
Unable to switch on beyond a faint blank screen no matter what I do to reset it
serial at the top and v1.06 at the bottom
and my usb base is dameged
Mar 14, 2008 | LG KU990 Viewty
Not able to turn on my hp ipaq hw6965
sir u have to contact vendors or service center coz they r having softwares to upgrade os  for pda's might be a virus has entre ur phone while upgrading windows good luck
Oct 17, 2007 | HP iPAQ hw6515 Pocket PC
Siemens SX66 Logo
169 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
