Reply to answer
Thanks for the quick reply.
Everything looks good. Usage around 6%- 13% for both processes and performance. Not really sure about the printout for sysconfig, there seems to be a lot of options there...
Owen
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello
You need to erase your pagefile, then your running applications you dont use, like toolsbars, monitor printer programs or scanners.
Posted on May 30, 2008
Will IBM Spacesaver II Keyboard work windows 7 64?.
just plug in ps/2 and the plug will take control of the controller
and you would disable bluetooth or turn it off
go into control panel, look for device manager
go down to bluetooth right click and select disable or remove driver
reboot everything should run fine
Jan 23, 2014 | IBM SpaceSaver II Keyboard
Hello,sir or madam how can i deactivate outo reply sending messege in my mobile phone?please help me in this matter. my cellphone model is samsung s5233 thanks
There's a particular subset of From addresses that we won't reply to. We look for things like "auto" and "no-reply" in the address the mail was sent from and if we find them, do not reply.
You could add a matching pattern to your FogBugz code and recompile, or you could have the messages come from something like do-not-reply@example.com, which shouldn't be replied to.
link'flag
May 25, 2011 | Cell Phones
My computer is being hanging
Goto Strart and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'Sys config utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
goto 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications .
right click on each applicaion and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, trojan, or spyware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
If you feel that my answers has helped you in any way then please give a vote.
Thanks.
Apr 08, 2011 | Computers & Internet
Hello, I have a F&P Smartdrive 5.5 Excellence washing machine. Am I able to reduce the amount of rinses it does? It appears to be performing 2 rinses and I would like to cut it down to one only as we...
Hi just read your posting.Now the 1st rinse cycle is always a spray rinse when the machine is set at the factory.If you follow these instructions then the 1st rinse will be a short spin only,with no water usage.1---Select the OPTION ADJUSTMENT MODE by pressing and holding the START/PAUSE button, then pressing the power button.Then release both after about 2 seconds. 2---Press either SPIN SPEED button to turn on the SLOW light,which is the spin only mode on the 1st rinse. 3---Once the SLOW button is lit push the POWER button to return the machine to normal mode again.Hope this helps and please reply back to let me know how you got on.We are on tank water too but thankfully we have a good bore.Looking forward to your reply and good luck.
Jul 11, 2010 | Fisher and Paykel Washing Machines
We need new wheels for our lower basket
Hi, Welcome to "Fixya" ! You can find these lower rack support roller & clip assemblies at "repairclinic.com" for around $10ea. Their part number is 1156665. They are really easy to change as you may already know, they snap in place. Hope that is the answer you where looking for, let me know. Thanks for visiting "fixya" with your inquiry. Please take a second and rate my answer accordingly or if more assistance is needed post a reply. Good luck. Macmarkus :)
May 04, 2010 | Asko D1776 Built-in Dishwasher
Exilim ez x60 with good lcd but no image
THAT MIGHT NOT BE A BAD IDEA, AS THERE SEEMS TO BE A BIG MARKET ON EBAY FOR LCD SCREENS AND DOORS.PCB'S AND MISC. PARTS, DUE TO THE HIGH COST OF REPAIRS. YOU PROBABLY CAN RECOVER A GOOD PART OF THE COST OF A NEW CAMERA. I WOULD RECOMMEND THIS SINCE NOTHING ELSE HAS SHOWN UP. SORRY THAT WE COULDN'T COME UP WITH A BETTER ANSWER, BUT SOMETIMES THESE THINGS ARE REALLY HARD TO FIND. THANKS FOR THE REPLY. I WOULD LOOK INTO EBAY. THANKS.
Dec 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Reply to aeg lavamat w1450
Further to your prob with washer, I would be inclined to think that there is a foreign object in the drum.Hopefully it will find it's way in to the pump filter.I don't think it will cause a problem
Merry xmas.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
USB problem
have you check with other usb devices if yes then your port is not working,
May 12, 2008 | Toshiba Satellite A135-S2276 Notebook
Kenmore SS Freezer Icing Up - Frig Side warm.
hi. buck. thanks for the question . most problems with that fridge is the defrost thermostat. I would replace it. thanks the appliance doc
Nov 27, 2007 | Maytag 23 cu. ft. Side-by-Side...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
