Question about Siemens SX66
Can't reset tried to upgrade but the screen went black saying: serial or USB at the top part and at the bottom, v2. 07
    Genius:
  • 1,142 Answers
Do a hard reset take the battery out leave it for sometimes may be 15 20 minutes and then put the battery in and turn on it should work fine
Posted on May 23, 2008
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Not turning on
Hi there, I think you pressed some more buttons and accidentaly you entered your device into Serial Mode (Bootloader), which you should update your ROM or reinstall your existing ROM in order to exit that state. I am sending you a link to HP website including your device's ROM upgrade download link, and a complete list of instructions. First of all, connect your device with a usb cable to your PC and see the "USB Mode" in the screen of your PDA. Also please be carefull and read the instructions very carefully before starting the process. Here is the link: (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ip-55697-1〈=en&cc=us&idx=0&mode=4&) Hope this helps. Have a nice day.
Apr 20, 2009 | HP iPAQ H2200 Pocket PC
MY SCREEN IS BROKEN..
Its supposed to shut off unless you have a higher end camera.Upgrade.
Jun 02, 2008 | Samsung Digimax S630 Digital Camera
Screen
I would recommend using Pocket PC 2003 version normally. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Below, instrutctions on getting ROM for PPC 2003:
Try www.xda-developers.com and ebay for ROM upgrades. There are many people who unlock these kinds of devices. I don't believe you can upgrade it to WM 5.0 or beyond, but that may be possible. Search for WM versions that include "unlocked" versions. The best bet is a newer version of PPC 2003.
The process is relatively simple. Once you have your ROM on CD or via download, You run it with your device hooked up to your PC via cable/cradle and connected via ActiveSync (3.7 or later). The warning is an improper ROM load could make your device unusable. It is a risk you have to take if you want it to make calls. Toss up: no phone Pocket PC, pocket PC phone, or shiny brick. If the XDA site has recommendations on a ROM source, they are not likely to steer you wrong. They will state emphatically, that you do not want any interruptions in the ROM upgrade process. If you have a power outage or something shuts off for any reason, you will have the shiny brick and be looking for a new device.
May 23, 2008 | Siemens SX66
Not able to turn on my hp ipaq hw6965
sir u have to contact vendors or service center coz they r having softwares to upgrade os  for pda's might be a virus has entre ur phone while upgrading windows good luck
Oct 17, 2007 | HP iPAQ hw6515 Pocket PC
Unsucessful Rom Upgradation Error
OK your phone is most probable stuck in bootloader mode and needs to accept a USB connection with the correct ROM image to be reprogrammed. You will see on the screen that there stands Bootloader/Serial if you look carefully. Check if you can see this text. Try a master reset on the phone as per rom installation instruction. (Top mennu buttons and reset simultaniously). Let me know there are more ways to solve the problem.
Sep 10, 2007 | Orange SPV M2000 Pocket PC
O2 rom upgradation
I think the upgrade, when finished would give the instructions to reboot the handheld. Upgrading mine did. It explained I must hit the (On) button and the reset (hole) at the same time.
Sep 06, 2007 | O2 Xda II mini
O2 Pocket Pc stopped working after upgrade installation
flash arom directly from bootloader mode (by pressing camera ****. and keep press. then press with sylus the soft reset ****. ,
then the 3 colors shows with usb in left bottom site of screen of device then run the flash utility normally .
May 06, 2007 | O2 Xda II mini
Open Questions:
Dial[ _[1$877$7788969]_]Blackbaud mail customer careUSA? Blackbaud Email CustomerTechnical Support 1-877-7788969 Contact number. Get any of troubles facilitate via contacting Blackbaud Email technical support Number1-877-7788969. North American nation 1-877-7788969 24/7 Blackbaud Email TechnicalSupport Toll free number 1-877-7788969 for password recovery and counter hacking solutions: The users will simply recover and even reset their email account passwords with the assistance of the support center at Blackbaud Email Customer Support Toll free number we'll support you fastly and solve user problem.By approaching the toll free number 1-877-7788969 accommodated the help of consumer you some help with willing be related to the authority Blackbaud Email specialised bolster focus. Structure here you'll pay special mind to the arrangement of any issue with reference to Blackbaud Email. it's unlikely that you simply get expertise with issue whereas utilizing the Blackbaud Email nonetheless it's perpetually nice to stay precautions somewhat going for cure. On the off probability that you simply keep the helpline number 1-877-7788969 with you then you'd have the capability to realize the bolster group at no matter time and from anywhere. Blackbaud Emails service center number,Blackbaud Email customer care number,Blackbaud Emails support contact number,Blackbaud Email usa support number,Blackbaud Email Customer support number,Blackbaud Email technical support.
May 26, 2017 | VIA Computers & Internet
See all Siemens SX66 Questions
Siemens SX66 Logo
166 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
