Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin will not wind
I am having problems getting the bobbin winder to engage. When the correct bobbin in set up and ready, I depress the foot pedal and it just makes a whirring sound but does not turn.
  • stewsbride May 23, 2008
    I do not understand what you mean by "you can get set" please explain
    Guru:
  • 1,894 Answers
Lubricate them..
you can get set
Posted on May 23, 2008
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
Cannot wind bobbin as pushing switch to left does not make the bobbin winder rotate
you might check with the place you bought the machine from and
ask them why your having a problem with the bobbin winder spindle
also ask if this is a common problem with the machine, you might
want to return the machine and get a different one or even a different
brand sewing machine
Jan 04, 2013 | Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
88 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
