Question about Electrolux EW1000i Front Load Washer
Put clothes in washer pressed start screen lit but was blank
  • Electrolux Master
  • 17,130 Answers
Possible that the program controller board is defective. You will have to check the control board for the failure of the display , it can be a faulty microprocessor or a power supply failure.
Check for the +5 volt to the mP IC, if absent check regulator. If present check the mP osc. in the crystal and the allied circuits.
Posted on Sep 27, 2010
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Maytag MGD 9700SQ. When I press start, the sensoring light clicks on and that's it. I've cleaned out the lint, cleaned the sensors with alcohol. Will clean the vent, but it seems like a basic fix....
Hi Jamie: After checking all of this and if it still dont work you will need to put in a new control board.
Plug cord into live electrical outlet. Check for proper voltage.
Check fuse or reset circuit breaker.
Push any key to turn ON the clothes washer and press the Rotary Cycle Selector knob to start the clothes washer.
Close door and push the Rotary Cycle Selector knob to start the clothes washer.
Check to see if the clothes washer is in a pause, soak or suds period in the cycle. Wait briefly and it may start. If washer is in suds period, SU and DS will display alternately, instead of the time remaining.
Check for restricted drain system. If there is an electrical problem in the drain system, ND error will occur after 15 minutes.
Check water supply.
Check the line screen and water valve screen.
Check for loose connections at machine control board terminal connections
Replace machine control board.
In this link, with your model could find parts replacement:
- Maytag-Parts/Dryer-Parts/Model-MGD9700SQ
- partsearch/model.aspx?model_id=5140219
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 06, 2011 | Maytag Washing Machines
Monitor problems--screen is blank but power button lit
Check you video card first, if you can remove it, then have it clean, the contact with an pencil eraser, just make it sure wipe the eraser residue, then put it back again, also check the built in fan on your video card, make it sure it is running
Nov 02, 2009 | HP vs19 (Silver) 19" LCD Monitor
Blank screen on my x205-s9349
when u power up press F8 key u get enble vga mode if it is your resolution problem then enter in wenable vga mode.
Mar 16, 2009 | Toshiba Satellite X205-S9349 Notebook
Computer display is blank
Suggest you contact store where you purchased item from, or contact repair agent, if you start messing with it , you will invalidate your guarantee.
Nov 30, 2008 | LG WM-2277HW Front Load Washer
Samsung electronics clothes washer model j845
If you have a face icon lit up the child lock is on, press and hold spin and rinse buttons until it goes off
Apr 26, 2008 | Washing Machines
Blank screen
hi friend
here is link for u 24 hour online service tecnision 4u
contect him diis cribe ur hole the problem he will gave u a solution
here is link for u
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&lang=en&product=500508&dlc=en
Mar 31, 2008 | Compaq Armada M700 Notebook
Blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Feb 07, 2007 | Frigidaire GLTF1240A Front Load Washer
Electrolux EW1000i Front Load Washer Logo
131 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
