Question about Tomtom GO 910 GPS Receiver
Tomtom1 memory card
When i turn this on it says the memory card is not inserted when it is
  • 868 Answers
Memory card slot pin switch is bad.replace the circuit board
Posted on Jun 02, 2008
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Jun 22, 2014 | Pentax Optio Cameras
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I put my memory card in my camera and it has a message that says no memory card. What do I do
I suggest you to turn off your camera and then turn it on. Or you can also re-insert the memory card.
Thank You.
Aug 02, 2010 | Canon PowerShot SD1000 Digital Camera
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Tomtom1 keeps restarting itself
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Aug 20, 2009 | Tomtom One XL GPS Receiver
N 72 hangs when inserted a memory card
hi there!
How much GB did you inserted?
Did you tried turning off/on the phone? Did you tried turn on the phone without inserting the memory card?
Regards,
Feb 19, 2009 | Nokia N72 Cellular Phone
Memory card
memory card is bad, repalce it
Oct 24, 2008 | Vivitar DVR 530 Flash Media Camcorder
Tomtom1 memory card
Through TomTom's company
Jun 02, 2008 | Tomtom GO 910 GPS Receiver
Tomtom1 original
You cannot use a card from another tt. The navcore and maps are for that individual device only. Check the tt forums you can find a wealth of information on them.
Mar 06, 2008 | Tomtom ONE GPS Receiver
Tomtom1 memory
The way the TomTom One works (unfortunately) is that it reads either from the SD slot of from internal memory, but not both. So you can't have the SD act as supplemental memory. I had the same problem and was pretty peeved about it. You would have to spring for a more expensive model to get this feature :S
Oct 04, 2007 | GPS
Tomtom GO 910 GPS Receiver Logo
56 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
