Question about Microwave Ovens
Light does not come on, first switch on of appliance and light does not work
  • Microwave Ovens Master
  • 17,130 Answers
If there is no action please do not switch on unless you have confirmed the fault.The door switch can be faulty and unless it contacts the light wont come on.
If microwave is not working check this out: It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step dwon suppy, the pads are responding- if not fauty pads- or the door switches ,if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Posted on Sep 27, 2010
My light stays on when I close the door.
If the light stayed on AND the tray kept spinning around, or a fan kept running, then I would say you have a bad door switch. But if everything else works like it is supposed to, then you probably have a relay on the main control board that is stuck closed (on) or you have a shorted triac on the main board. Since very few technicians troubleshoot down to the component level or repair boards, you are probably looking at a board replacement - a rather expensive proposition to fix a light that is stuck on.
Jun 15, 2016 | Emerson MW8999RD 900 Watt Microwave Oven -...
Kenmore spacemaster microwave Auto recipe 300 will not light up or do anything at all
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 31, 2011 | Microwave Ovens
Fuse intact in supply lead but Neff H5470NO appears 'dead' - nothing working and no indicator lights is there another fuse ?
Hope this helps.
Feb 16, 2011 | Neff H5470 Microwave Oven
I have a Sharp Model 1460A Microwave. It quit working while warming something up yesterday. Outlet is good. No power to unit at all. No light working, etc. Is there a fuse that I can check to see if it...
Hope this helps.
Feb 07, 2011 | Sharp R-1460 Microwave Oven
Have a GE Monogram Microwave model ZE2160SF 04 and display does not come on nor does the unit work any longer. It went out while in use. Also a note that the light inside dimmed and when out as the unit...
Hope this helps.
Feb 07, 2011 | GE Microwave Ovens
I have a 20-yr-old microwave--a kenmore 565.8824581--that just suddenly stopped working. no lights, nothing. offhand do you think this might be a fuse issue that is fixable, or would this simply warrant...
Hope this helps.
Jan 21, 2011 | Microwave Ovens
How to access and find fuse in magic chef (installed under cabinet) microwave. No power to microwave (nothing working including light)
Hope this helps.
Jan 02, 2011 | Microwave Ovens
Maytag over the oven microwave. Made funny noise and quit working. no light , no clock, no sign of life. Checked circuit breaker, ok. Any ideas?
Hope this helps.
Dec 31, 2010 | Microwave Ovens
I have 3 years old Panasonic microw wave model NN215MF. When I switch it on, there is seems to be no response, it does not light up and remains silent as if there is no power. Kindly help. My email:...
Hope this helps.
Dec 09, 2010 | Panasonic Microwave Ovens
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
