Question about Black & Decker String Trimmer Cordless 12" 18V
GH1000 string trimmer
The belt slipped off the drive pulley but even though I have all the screws out of the case there is something near the button that releases the shaft that is keeping the case together. Is there a trick to getting it apart?
  • 1 more comment
  • Anonymous May 26, 2008
    my drive belt flew apart and I need to know where I can get a new one. Derf.
  • Anonymous May 31, 2008
    I had the exact same problem.  Thanks for the tip.
  • tony barg Apr 19, 2009
    I just cant figure out how to extend the string
    out , it is suppose to do it automatically when you press the trimmer down on the ground and turn on but it never works . i do it manualy and it only last about seconds then it needs to be extended again . what am i doing wrong?
    Tony
This is for the Black and Decker GH1000 string trimmer. There are 20 screws to remove altogether. The last screw is under the black label with instructions on using the button to extend the shaft. The screw hole is just above the white line on the label-you have to poke a hole in the label! Very tricky!
Posted on May 24, 2008
Look under the label just behind the swith. There is a hidden screw there. Hope this helps someone
Posted on Apr 26, 2009
REMOVE THE STICKER ON THE LEFT SIDE OF THE MACHINE. THERE IS ONE SCREW UNDER the sticker.
Posted on Aug 19, 2010
4 Suggested Answers
  • 313 Answers
SOURCE: re: GH1000 Trimmer - looks
there is one hidden screw under the label. fell with your hand the label where the screw located.
Posted on Jul 24, 2008
  • 3 Answers
SOURCE: Black and Decker gh1000 type 2 string trimmer the
I had the same problem, there is another screw hidden under the black sticker. If you feel around, there is a soft spot. That's it.
Posted on Jun 02, 2010
rycgl
  • 1545 Answers
SOURCE: Belt replacement on Black and Decker GrassHog XP -
I have never worked on these units so I am sending you a parts breakdown diagram, so you can maybe solve your disassembly problem.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=GH1000&selectedType=16880
Posted on Jul 24, 2011
Timing belt on weed trimmer
Instructions
    • 1
      Stand in front of the edger and take a look at the existing orientation of the drive belt if it's still on the lawn edger, and take a photograph of the routing with a camera. Cellphone cameras are good for this. This will help you put the new drive belt on correctly. You can also draw a sketch by hand.
    • 2
      Loosen the flange nut on top of the frame, letting the idler pivot assembly pivot a little. Reach into the back of the edger and pull off the existing belt from around the flywheel pulley. Then remove the spindle belt guard by removing any screws you see there. Remove the belt off the further pulleys and throw the belt away.
    • 3
      Place the new belt onto the spindle sheaves and route it back through the pulleys using your photograph as a guide. In all cases, the belt has to be on the engine flywheel pulley and the idler pulleys. The "Y" on the belt seats into the top pulley and the flat part goes into the bottom. Re-install the spindle guard and re-tighten the nut on the frame that you loosened.
Car Headlights.
Jun 01, 2012 | Garden
Operator's manual for black and decker string
copy and paste this url and you can print it off at your home or office. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90556296,GH1000.pdf
Jul 05, 2010 | Black & Decker Garden
GH1000 Motor runs but spool just quit working.this is electric.
Same thing happened to me. The belt broke. You'll need to take off all the screws to change the belt. There's a hidden screw under the black label. Feel around for the soft spot.
May 21, 2010 | Black & Decker 14" Grass Hog Xp...
ENGINE WILL NOT ENGAGE WITH SPINNING SPOOL
I had the same problem, The pully is plastic and is mostlikely melted. I took mine apart when it finally stopped working and found that the belt had broken as well. When taking it apart, there is a hidden screw under the black sticker label. Just feel for the soft spot. Also, there are screws under the black plastic embelishments.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
May 25, 2009 | Black & Decker Garden
Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
568 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
