No power My TV does not turn on at all. I have tried from the remote and the TV's on/off switch and it still will not turn on. mitsubishi vs-80502 1998 no power or remote power
  • 1 more comment
  • gogopappy060 May 26, 2008
    Nothing happened the LED light isn't even coming on.
    The power button on the front of the tv, that board is cracked only where the power button is.
    It looks like it cracked thru the brass or copper strip separating power from other controls.
  • Anonymous Sep 07, 2008
    fuse location on power pcb
  • 8,617 Answers
Does the power led light? If so press menu and input in on the set together and hold them both in for 8 seconds to see if the led will blink a two digit error code. Then let me know what happend.
Posted on May 23, 2008
  • Sonny Berry
    Sonny Berry May 26, 2008
    check the fuses there are several on the main PCB board. one has to be blown if the led isnt lighting
  • Sonny Berry
    You can repair that by soldering a piece of insulated wire to jump across the break.
How to turn on tv
Hello, try holding the power button for 5 seconds and see if it will come on, otherwise try a universal remote programmed to a mitsubishi tv. If it still won't come on it might have a problem in the power supply....tks
Nov 08, 2013 | Mitsubishi VS-60707 60" Rear Projection...
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-60703 60 in. Rear Projection Television: I was wondering if anyone could help me out with a question I have about my Mitsubishi big screen TV, model # VS-60703? My TV powers on and off, but...
try unhooking the switches and see if it will work with the remote only.
http://www.fixya.com/support/r5000958-fixing_mitsubishi_rear_projection_tv
Let me know if I can be of further assistance.
Jun 09, 2010 | Mitsubishi Televison & Video
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
I have a Mitsubishi VS-45605 projection TV and a Philips DVD player model DVP3962/37. Can anyone help me figure out how to program the remote to control the DVD player? I only have the original remote for...
I've got the same tv and...I've still got the manual!;-)
Programming the Remote to control other audio and video products:
  1. Move the slide switch at the top of the remote to select the a/v product you want to control (in this case, DVD).
  2. Press and hold the Power button so that it stays down when you enter the code.
  3. Enter the code for the equipment. Release the Power button
  4. Point the remote at the equipment and press the Power button. If the equipment respondes, you're done. If not, and you have more codes that apply to that equipment, go back the step 2 and try the next number.
If none of the numbers work, I'm afraid you might be out of luck.
Oct 20, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Tv not coming on
try removing batteries from all remotes, a faulty remote may be turning your TV on/off. If it still does this, there is a power problem and you likely need a tech to look at it.
Dec 09, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
Oct 26, 2008 | Televison & Video
VS-50705
Power off is when you press the switch.
Shut down is when you turn off from remote and TV stays in standby with led on.
Jul 18, 2008 | Mitsubishi VS-50705 50" Rear Projection...
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
