Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Intermittent problems when turning on my TV. The screen will flash (please wait) then go blank,the sound remains on with no video. At times you can switch it on and off several times and it will come on and others you need to unplug it and wait a few miniutes, also works. Is this repaiable at home?
  • Sharp Master
  • 736 Answers
This sounds like loose inverters. You may have to do some soldering so if you're not completely familiar with how to correct this you wouldn't want to do this at home.
Posted on Sep 28, 2010
Turn on unit. Red power light is on. No picture, no sound. Turn unit off, hear a click and a small square flash on the screen. Did the same thing 2 months ago, let it sit for 3 days and then it was...
It seams to be a problem in video and video out put stage some TV set design there is no video signal the sound out put also not working this TV high voltage ( horizontal out ) is working fine that why flash squre visible when the sw off. may be dry joints in the video section or some auxilary power supply cricuit feeding power to video section having a problem
Sep 04, 2010 | Toshiba 27A60 27" TV
TV PICTURE GOES OUT AND THEN SHUTS OFF
sounds like dodgy buffer board or video pcb
Sep 25, 2009 | Televison & Video
I have a 51HW40 sony TV. A few problems green horizontal retrace that curves flashes green and turns off (about 2 times a month) I wait turn it back on and its fine Codes that have been tripped: 6: Low b ...
Hello: Have you tried to adjust you Green Screen control on the focus block assembly. located behind the front panel assembly. Here is a solution that might help you, turn off the green by turning off this control, make sure u look at the block and make sure you are not turning the green focus knob instead of scrn crl. Turning the control slowly to the left the retrace lines should disappear as the green video darkens. Then turn the control slowly to the right just until the retrace lines reappear, then turn back slowly left just until the lines go away. If the screen is Blanking on green tube only then you have a video blanking problem on the main signal board. Or possibly a IK bias problem. It is also possible that the green CRT is defective. The FBT is not bad because the screens are lighting up indicating you have high voltageand heater voltage which is derived from one of the secondary windings of the FB. If it is a Blanking problem i would look into replacing the A Board assembly.
Sep 25, 2009 | Sony KP-51HW40 51" Rear Projection...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
TV MODEL 32PF9631D 2 YEARS OLD INTERMITTENT FAULT BECOMING MORE FREQUENT - PICTURE DROPS OUT LEAVING BLANK BLACK SCREEN (ALL CHANNELS INCLUDING FOXTEL) BUT SOUND REMAINS. TURNING TV ON AND OFF WILL...
You have problem with the power inverter, in you tv it might be part of the power supply, in which case you will need just one board. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
No video on LCD 32' insignia
If you have audio and no picture shine a flashlight across the screen and see if you can see a very faint picture on the screen.
If so the backlight drivers need to be replaced... A shop job unless you want to risk breaking the screen - and not terribly expensive.
Bill
Nov 09, 2007 | Insignia IS-LCDTV32 32 in. Television
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
338 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
