Question about Dryers
WHIRLPOOL DRYER NATURAL GAS ATT. CARE 2 MODEL- LGQ9508LWO SERIAL mp0603131 TYPE DWSR-NAT 1206006-CV22 22,000 BTU JSUT STOP HEATING UP NO MATTER WHAT CYCLE OR DEGREE SETTING WHAT PART SHOULD I CHECK FIRST THEN NEXT THEN NEXT THANKS
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer
If it does not heat at all your glowbar ignitor is bad.
If it heats and does not re-light your gas valve coils are bad.
Posted on Apr 03, 2011
MR0849046 DWSR-NAT-1206006-CV22
Could be the element or any of the fuses.
Jul 12, 2014 | Kenmore Dryers
Dwsr nat 1206006 cv22 fm22 whirlpool ser
take a picture or more info where is it center side back wall ?
Nov 09, 2013 | Kenmore 74602 Gas Dryer
Hi more info. I posted wrong. my dryer is model 11079912990. ser # mj1607152. type ddot-nat-1206006, cv22. 120 volt, 60 hz. 22000 btu .27 inch wide kenmore gas dryer. The dryer would run for a few...
You could have a blown fuse because of a clogged vent or a bad thermistor. A thermistor is used by electronic controls to measure temp changes inside the dryer. If the sensor is open then the brain does not have a clue how hot the dryer is. So it shuts down. Repair clinic has an excellent thermistor replacement video.
Oct 25, 2013 | Sears Kenmore 7.3 cu. ft. Gas Dryer Model...
Dryer is not heating up. All cleaning of any build up has been completed. serial no: my1804125 type dwjr nat 1206006 fm22
There are multiple thermal fuses and also a thermostat and last is the heating coil itself.
Aug 19, 2013 | Ovens
Does it have a pilot light?
yes it is electronic called a pilot generator
Jun 14, 2012 | Kenmore Dryers
Whirlpool dryer dwsr nat 1206006 fm22 will not turn on when on button is pressed. There is a black plastic piece to the right of the metal catch on the dryer that if pressed the right way, the dryer will...
The peice your refering to is called a door switch, and its a pretty easy repair. You'll need your model number handy, and then contact a local parts distributor in your area. Once that is done, if your dryer is a standard whirlpool, you'll just take the two screws out of the top by the lint trap and pop the top up. Once thats done look down to the right and you'll aee the switch which is held in by two screws on the outside portion of the door.
Apr 28, 2012 | Whirlpool Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Dryers
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Dryers Logo
124 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
