Question about Kitchen Ranges
My Mac Clean Intellis IS100 water softner is restricting the water flow into the house. When I turn the Bypass on, our house water pressure is great. When I return it to the Service mode, our pressure is good for a few gallons and then drops off dramatically.
  • gpe79 Mar 06, 2011
    Was there an answer to this issue? I have the same problem with the same unit.
    By cnegri on Sep 27, 2010
  • RickC
    RickC Nov 20, 2013
    Was there an answer to this issue? I also have the same problem with the same unit. By rickcole on Nov. 20, 2013 My Mac Clean Intellis IS100 water softner is restricting the water flow into the house. When I turn the Bypass on, our house water pressure is great. When I return it to the normal mode, our flow drops to about half.
keemo68
  • 1263 Answers
SOURCE: Oil Pressure Drops While Driving
your oil pump is either weak or there is sludge i9n the oil pan. my adives is to have the oil pan dropped . chances are sludge is the culprit. as the oil get's warm the pressure should only drop slightly but pressure is generally dictated by engine rpm. pumps are gear driven so if it was a bad pump your oil pressure would start out very low at start up.
Posted on Aug 28, 2008
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
  • 172 Answers
SOURCE: Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Posted on Jan 21, 2010
  • 569 Answers
SOURCE: i have a water softner
To try and answer your question I will assume firstly that 'in service' means in normal operating mode - not in re-generation.
All water softeners have a limited throughput of water. In other words the volume of water that can pass through the system and be softened in the process is limited by the size of the vessel. If water passes through at too fast a rate then there would not be sufficient time for the water to undergo the ion exchange process that softens the water. Therefore the softener constricts the flow to a level which provides satisfactory operation.
If your plumbing system is taking water directly through the softener then the pressure will be limited by the maximum throughput of the softener. The only way to solve this is to install a higher capacity softener or, as is common in the UK, to feed a cold water storage tank from the softener so that pressure is not affected.
If you mean that 'in service' is when the device is re-generating, then the problem is a different one. When the device re-generates, it switches the water flow to bypass the softener within the unit. Therefore the pressure should not be affected unless the bypass is partially constricted. This bypass valve is an integral part of the softener valve assembly, so this would have to be checked by a competent service engineer.
If you can provide additional information by posting a comment I will do my best to help further. If you do so please identify the brand and model of your softener and try to describe how it is plumbed in to your supply.
Posted on Apr 13, 2010
Testimonial: "thank u its was clogged "
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
My pressure is bad
Most likely a failing water softner. Have it services asap. Or replace the resin yourself but do it quickly. Bypass the softner in the mean time. There is a valve assembly on the head of the softner. Set it to bypass.
May 08, 2014 | Addie Water Systems Metered Water Softener
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
Water pump says we have 50 pounds pressure but very little water flow
Don't trust the gauge all the time. It may be stuck at 50 psi. Are there any in-line filters restricting flow, softeners or iron filters that may be restricting flow. Bypass any system and check flow rate.
Check outside spigots for water flow. There could be a problem with volume from well also.
RJ
Jun 26, 2011 | Flotec Plumbing
House water pressure is 90psi static, when a faucet is turned on pressure drops to 35psi and water output is considerably less. Why and how do I fix it?
To cause the pressure and flow drop you are experiencing indicates a major restriction in the the main supply pipe to the house. The stop **** where the house supply is connected to the street main would the place to start. Find the faucet that is closest to this and check the pressure/ flow and if that is OK continue to each sucessive faucet in the line. You should be able to narrow down where the restriction could be. Yuo may need the help of a plumber to fix the problem.
If the piping is the very old style galvanised steel pipes. then the rust/corrosion buildup inside the pipes would cause the restriction and is indicated by rusty water coming out if the water has not been used for a few hours. Total replacement is the only fix for this problem.
Sep 20, 2010 | Plumbing
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
Kitchen Ranges Logo
489 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
