Question about NetGear WGR614 Wireless Router
I am not able to connect internet to my laptop using netgear wireless router
    Novelist:
  • 125 Answers
Hi Prema Shanka,
I got your issue check what is the wireless settings on your router and connect to the network wireles it will work
Thanks,
Prema
Posted on Sep 27, 2010
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
TBlessed 1
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
  • 9 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Posted on Dec 22, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
Netgear router N 300 cannot connect to the internet using laptop
There are many router related settings on NETGEAR wireless router and if these are not configured properly, then issues such as router not connecting to Internet might come up. All NETGEAR wireless router users facing router not connecting to Internet are suggested to verify the router related settings such as access points and reconfigure them if required. Users are also advised to check the firewall settings on the system and ensure that they are not blocking the connection.
Jul 03, 2011 | Computers & Internet
Netgear WGR614v7 Wireless Router what do i need to use google,com
Search for wireless networks from ur laptop. u will find ur wireless router gets listed. Select it and click on connect. Your router assigns an ip to ur laptop by means of dhcp. Thats it u get connected to internet. ensure whether ur phone line is connected to rj-11 port of ur wireless router
Jul 21, 2010 | NetGear WGR614 Wireless Router
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear WGR614 Wireless Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
