Question about Samsung SCX 4521F All-In-One Laser Printer
If fuse blown error shows, fuse (1.6mamp) if it replaced to (0.5 amp) then it works.
    Problem Solver:
  • 9 Answers
Change the fuse with (0.5 amp).
If it doesn't work try this:
From Samsung site:
1 Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2 Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3 Press the left arrow (4 Press ENTER. The operator panel will display [YES].
5 Press ENTER. The toner warning message should be gone.
6 To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Then you don't need to use fuse after that.....
Posted on Sep 27, 2010
A6 turbocharged. Whyu does it smoke when it covers a 120km per hour?
I am going to say 'blown turbo'. As I understand it, they needs replacing every few years. They are susceptible to heat and incredible revolutions. They have to be lubricated, the seals go, and you get smoke.
Mar 20, 2016 | Audi Cars & Trucks
Gauges not working
all gauges, what about idiot lamps in the cluster.?
does car run?
head light work.?
no matter, it's just a blown fuse.
the glove box operator guide shows the fuses.and all names..
lost that?
free
http://justgivemethedamnmanual.com/honda/honda-accord-owners-manuals/
fuses that look blown are
fuses that look good, can in fact be bad, hairline cracks. so we use
a $20 tool called and ohmeter (DMM set to ohms low)
0 ohms good
infinity bad.
Dec 30, 2013 | 1995 Honda Accord
Blown 24v Slow Blow Fuse
Scott, I have the exact same problem. What ended up fixing this? Thanks! - Paul
May 10, 2013 | Honeywell Triangle Tube Prestige Solo 110...
My machine shows an error number E1what is it
The error code 1 indicates the fuse on the A board has blown. The fuse should be replaced with a part number 000182177 fuse. The original fuse is a 2.5 amp fuse and the replacement fuse is 3.15 amps.
You should take the sewing machine to a Sears service center or a retail store for repair.
Sep 11, 2012 | Kenmore Sewing Machines
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
Headlight are not working
Sounds like a blown fuse. Have you checked the fuse? The owner's manual should have a diagram of the fuse box showing what each fuse is for. Locate the fuse box...usually under the dash board next to the driver's side door. Pull the fuse for the headlights and shine a flashlight on the clear plastic part of fuse. If the wire in the plastic part is broken, then the fuse is blown. Many gas stations carry fuses, make sure to replace it with a fuse having the same amp rating. Fuse should have the amp rating written on it (5, 10, 15 amp etc.).
Good luck
Apr 26, 2010 | 1997 Acura TL Series
My Whirlpool microwave is not heating. The light, turntable and fan is working. What is my next step? model MH2175SXQ-0
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 31, 2009 | Microwave Ovens
Red, Green, and blue
sell it on ebay as broke they go for 100 just a idea look like u tryed alot
Feb 05, 2008 | Sony KP-46WT500 46" Rear Projection...
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
