Question about Sony Handycam DCR-TRV460 Digital Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
I use the A/V wire to connect the Yellow/White/Red pins in my TV to my handycam.
Now when I playback a previously recorded Hi8 tape, the following is noticed:
a) Picture on TV appears in black and white
b) Picture continuously rolls
c) Sound is heard very clearly
  • 10,594 Answers
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
Posted on May 27, 2008
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Have just purchased a Video 8 Handycam . When I play the tapes on the Handycam the picture is just a series of horizontal lines. I have tried to view the tapes through the TV and just through the Handycam.
Did you purchase the camera used? This is often a sign of dirty read heads. Run a head cleaning tape, and that should take care of it. You might also check the tapes you are using. In the days of 8mm, there was 8mm tape, and Hi8 tape, and the two didn't mix well.
Jun 01, 2011 | Video Cameras
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Dont know how to play a tape from camcorder onto my tv
just insert the tape in camera and connect yellow to yellow port in camera and audio is white and red on the other side follow the color code on tv back panel or front if u have and put ur tv into AV mode and then play back ur camera tape using playback mode look out for switch with play icont on it to select the play mode in camera u are set watch it on tv u want anything else i am here to help u
pls rate me FIXYA for help
Apr 14, 2009 | Sony Handycam CCD-TRV57 Camcorder
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
288 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
