Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Two red lights flashing on epson d68. prior to this enquiry told printer woud not work until serviced.
4 Suggested Answers
  • 13 Answers
SOURCE: how to reset manualy the counter on epson d68
Manual instruction Resetter Printer Epson D68
  1. Switch on printer
  2. Open auto.bat to set the date to 19 June 2006
  3. Run adjprog.exe from the extracted folder
  4. Click accept
  5. Click particular adjustment mode
  6. Go to maintenance then Select waste ink pad counter then click ok
  7. Click on “check button till its done then click on initialization button then click on finish button
  8. witch off printer for 5 secs then switch on again
  9. After you reset succesfully, you can change the date back to normal.
Please rate my solution after reading. Thank you
Posted on Mar 05, 2009
aicaxz
  • 511 Answers
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at indoreset.blogspot.com. Reset the waste ink counter.Good luck.
Posted on May 29, 2009
  • 700 Answers
SOURCE: epson c48 printer
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
Posted on May 31, 2009
My epson shows two allternating red lights and wont do anything.It is a d68.
That light sequence indicates your printers waste pads are full.. or rather then printer thinks they are.
You can resolve the problem easily enough by getting it serviced at an Epson Service Center (prohibitively expensive unfortunately) or consider an external waste ink kit.
Resetting the printer may be possible using the SSC utility but I suspect you'll need an adjustment utility which should be available if you dig for bit.
In terms of fitting an external waste kit you can see a guide for the C86 which is almost identical in terms of case design here:
http://www.octoink.co.uk/kb/questions/31/Epson+C86
Hope that helps...
Martin
Mar 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Both ink and paper light are flashing alternate and I cant get the printer to work epson d68
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Jan 11, 2010 | Epson Office Equipment & Supplies
Epson D68 2 red lights flashing, the green light is not on and the printer seems dead
Fix it with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Nov 07, 2009 | Epson Office Equipment & Supplies
Epson D68 red light on constantly, checked the ink cartridges, then had 2 red flashing lights now back to one
Remove and reinsert the cartridges - the cartridge lid may be open.
Also, the printer may need to be reset. From:
http://ribensan.free.fr/
Select the Epson resetter, Save, unzip and run.
Hope this helps.
Sep 08, 2009 | Epson Office Equipment & Supplies
Hi my R1800 has 2 flashing red lights (top) and no power light. What can i do? MAria
Hi.
It could be your ink tray has overflowed.
There is software http://www.ssclg.com/epsone.shtml which might help.
Install this program, set your printer model and the driver (Epson Stylus Photo R1800) when it starts up. Close the program, and it will minimize to the
tray on the taskbar - right click on the icon and goto "Protection Counter". Choose
"Reset Protection Counter". Choose "Yes" to the question about the waste ink pads,
then switch the printer off for 1 minute. This should cure the problem.
It might be worth a try
Jun 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Lost my insruction manual for the EPSON STYLUS D68
The documentation for your printer is located HERE.
Mar 10, 2009 | Office Equipment & Supplies
I have an "Epson Stylus D68 Photo Edition". When turned on the Green light flashes on once and shuts off . Both Red lights lights flash alternatively and the carriage does not move. It's not out...
>turn it off
>check for any obstructions
>re-seat the cartridge
>turn it on
>if the lights flashes like it's Christmas, definitely a hardware issue.
check warranty status (Warranty starts from the Date Of Purchase) first before calling tech support for replacement.
Aug 25, 2008 | Office Equipment & Supplies
D68 epson printer,both red lights flashing alternately.
Fix with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Jul 14, 2008 | Televison & Video
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
