Question about Philips Health & Beauty
My philishave 384 not getting charged despite connecting to power and the charge light is also not geting on. How and where to repair it in kolkata ?
You need to replace the rechargeable battery by soldering a new ni-cad battery in place of the old one. Dont know the ampage required. Sorry. You need a torx 8 screwdriver to open it up.
Posted on Jun 26, 2011
  • JazzB Jun 26, 2011
    Correction torx 9
Philishave ho 5812
Model 5812 has not been made since about 2008. You may have just bought it 'new' but it is not fresh. The battery is probably bad.
Sep 19, 2013 | Philips Health & Beauty
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
I am looking for a manual for a Philishave Model 805 electric shaver. How do you know when the shaver is fully charged. The green light is always on solid from start to finish
I don't believe that there is an on-line model for this model as it is an older model. The charge time for this model is 16 hours. There is no indicator to tell you when it is done.
Aug 18, 2010 | Philips Philishave HQ8150 Electric Shaver
The laptop 5315 is not charging , no red glow
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 12, 2010 | Acer Aspire 5315 Notebook
Phillips 990 shaver new batteries
shaver batteries can be purchased at shaveroutlet.com
Dec 21, 2009 | Philips Philishave HQ7780 Electric Shaver
WHICH VOLTAGE HAS THE 2 BATERY PHILISHAVE TYPE HQ 6740/A
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
May 21, 2009 | Philips Philishave Cool Skin HQ6740...
Have a Braun series 8000 shaver battery not charging
Well if it's not charging at all and you are not getting any lights, then you could have one of two issues. Either you have a bad power cord or PCB board. If it's just not holding a charge then you can replace the Batteries.
Sep 23, 2008 | Philips Philishave HQ7780 Electric Shaver
Philishave HQ7780 not charging: dead, no leds
The connectors that attach the power cord in the solution housing have "rotted away". Look carefully at the pins and you'll notice they are gone or really corroded. Philishave will replace the whole thing shaver and all if you give them a call.
Sep 10, 2008 | Philips Philishave HQ7780 Electric Shaver
Health & Beauty Logo
281 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
