Question about Philips Televison & Video
Dear Mister, I'm owner of e PHILIPS 37PFL9603H LCD TV an i'm satisfied.My Problem is now, dat RTL LUXEMBOURG transmit his programm since 2month simultany to the normal digital quality also in HD an that like the other programms on terrestial way.But i have only the sound and no picture.Is it possible that the TNT Tuner on my TV is not yet able to decode MPEG4 signals.If this should be the case,is it then possible to make en upgrade. Im. waiting for your answer. With best regards Jean KNEIP 65,rue de Steinsel L-7254 BĂ©reldange
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
SOURCE: lumatron lcd tv we receive only two programms
I have a problem with my lumatron ftv-42p5 it shows a pink picture when i turn it on and first when I change the mode to scart2 rgb thw tv picture shows, but you can se that the picture is not ok it is a bite to white. If I try to connect my xbox. I cant not use it at all. solution??
Posted on Nov 11, 2008
  • 909 Answers
SOURCE: TV picture settings for best picture
The settings are purely your personal taste. Set to what you percieve as perfect for you, just play with all the settings, there are factory presets so you can't ruine it.
Posted on May 28, 2009
  • 10 Answers
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Posted on Apr 14, 2010
Philips tv won't hold programmes
try replacing channel up and down tact switch..this probably helps..
Feb 05, 2013 | Philips 27PT543S 27" TV
Finding a replacement RCA Remote Control for a 2005 RCA LCD flat screen TV-L26WD21
I think you are looking for a programmable remote for your RCA TV. Whatever one you have isn't it. There are a number of non-RCA programmable remotes that can transmit the code you need. The remote should come with a code list that includes RCA so it is likely you won't have to get involved with the code search process - just enter the appropriate code and you're all set.
Jan 05, 2013 | RCA Televison & Video
Programme reminder
Click here to download its owners manual. It have all details.
Aug 13, 2012 | Sony KDL32EX301 32 in. HD-Ready LCD TV
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
Looking for a owners Manual for a Philips 32" LCD
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link
Jul 30, 2011 | Philips 32PFL3505D 32 in LCD TV
I just dug up my Phillips Unversal Remote Control for TV, VCR,DVD, etc, however I no longer have its owners manual to dial up the code needed to operate my Sanyo TV. Will you please provide the 4 digit...
Please go to below website you can get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.ff32c84.jpg
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
Jul 28, 2010 | Philips Televison & Video
Televison & Video Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
