Question about Refrigerators
Ge profile refridgerator
Unit laid flat when it was delivered, now won't get cold.should I unplug unit until tech comes on tues.?
Unplug unit for 3 to 24 hours and then plug back in
it should work then
some of the oil inside the compressor must have travelled
up the pipes, if you leave unit upright and unpluged for at least
3 hours it should work
if this does not work you'll have to get repair man
Posted on May 23, 2008
The refridgerator party not staying cold... Freezer part is staying cold
Look into back of freezer and see if a layer of frost is building on rear panel. If yes unplug and manually defrost until you can get back with me with the model number. What you said is the first symptos of defrost not taking place. Look around door frame for the model and I will be back later with part numbers. Thanks, Sea Breeze
Mar 19, 2010 | GE Profile Arctica Stainless Steel Top...
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
No start up
No its not. Bad valves are caused by dirty filers,dirty coils that cause liquid refrigerant to slug compressor and knockout the valves. Rus
Aug 17, 2009 | Ruud UAMB Air Conditioner
My refridgerator is not keeping cold any more? what is the problem? The model is Ge GSS22WG. it does not freeze or keep things cold, all of my food went bad. I need help I dont have the money to buy a new...
it could be an air flow problem. Pull the unit out, unplug it. Clean out any dust, dirt, or anything else you see in there. Also when you push it back in make sure you have a few inches clearance behind and to each side of unit . Good Luck.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
I purchased a used GE Profile side by side refridgerator; it was used for model homes... Well I got it home and the lights are on but it doesnt seem to be working??? The buttons seem to be non...
if the unit was working before......unplug the unit, place it where it will be used, let it stand with no power for 24 hours.......then plug the unit in and check its operation after 24 hours....I know, sounds nuts, but this has saved many from buying a new unit......not all refrigerators like to be moved.
May 09, 2009 | Refrigerators
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
