Question about KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher
Water in base of washer, after cyle, unit does not totally drain water, about 1/2 inch of water
  • 3 Answers
Check drain hose for postion not higher than motor. to high
Posted on Sep 27, 2010
Washer fills with water but does not go to next cyle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl click so.
Apr 02, 2013 | Frigidaire FTF530FS Front Load Washer
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
The dishwasher fills with water when it it off.
The problem is the water inlet valve has failed. This is inexpensive and easy to replace. Here is a video that will walk you thru replacing this.
http://appliancehelponline.com/dishfloatwaterinletvideo.html
Jun 03, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water will not drain after wash or rinse cyles
sjjordan96,hey just had the repair guy come today. The problem is the one way valve on the washer was clogged. Its easy to get to just remove the bottom panel of the washer and disconnect the drain hose and clear the clog.
Jan 23, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Spin cyle
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER IS DRAINING BACK INTO WASHER
Based on your description, I'd look closely at the drain hose (the big hose going out of the washer and into the wall between the water valves). If it's stuck too far into the hole there without an air gap, it'll siphon water back into your washer. To correct this, simply lift the drain hose out of the wall drain a few inches. This will allow the water to drain and NOT allow a vacuum to form. (a vacuum will "pull" water out of the drain pipe and back into the washer thereby filling it while not in use)
Jun 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher
If your water level is below the heating element that is normal after a wash. Some unit the water will not always drain (relates normally to low water pressure or hose length or height)
If your water level is below the heating element and your dishes ALWAYS clean then its fine, the water drains out before a new wash so you are not using the same water
if water is above heating element, run garbage disposal to clear lines if one is installed, if not you could have a clogged line/hose/sump/filter
May 02, 2008 | Dishwashers
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher Logo
143 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
