Question about Garden
I took apart my crafsman 6.0 lawnmower to replace the power pull cord. the question i have is once I have the power cord is there a special way of setting the cord up in the spindal ? I had to take apart the top section just to have access to where the cord is held with a knot.
  • 391 Answers
This is the way I do it; first ensure the new pull rope is the same length (or close) to the original. Tie the handle to the new cord before rewinding the pulley spring up all the way, rotate the pulley as needed to align the hole in the pulley and the guide in the cover and then hold it with a "C" clamp or have a helper hold it tight (I prefer the "C" clamp).
Thread the new cord in place; if you have difficulties with the rope bunching up put on some gloves and with a torch (or stovetop) heat the end of the new rope until it just begins to melt and then roll it into a point to make it go through the little holes easier. For really stubborn ropes (keep the gloves on) if the pointed end helps but it's still difficult to thread all the way through I've found that after forming the point saturate the last 6-8 inches of the rope with melted Gulfwax or bee's wax. Once the wax is cooled a bit but still hot roll the the rope in your hands to form the end of the rope strait. Thread the rope through ending and locking with a small but tight simple knot. Release the Clamp and allow the rewind spring to wind the rope in.
Posted on Sep 27, 2010
  • aakillian Sep 27, 2010
    I HAD THE IDEA TO REPLACE THE CORD THE WAY IT WAS LOOPED THE ORGINAL WAY, BUT THE QUESTION I HAD IS HOW WILL IT REWIND ITSELF WITH THE FORCE OF THE SPRING ?
  • Mike Squire Sep 27, 2010
    You rotate the pulley by hand in the direction it would turn when you pull on the rope, this rotation loads (winds) the spring force used to turn the deep groove pulley and wind up the rope.
    If the pulley just spins and spins without ever tightening the spring that could indicate a broken spring or a spring that is no longer connected to the pullie's center slot. If this has happened it may be best taking it to a shop for repair at this point because I can attest that if the spring comes out of the rewind cover it's an absolute mess to deal with but a shop has special tools to work with.
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
My crafsman lawnmower keep idling high while i'm using it what could be the problem
throttle cable may have moved forward loosen cable and pull back a little see what happens if it slows down retighten done
Jul 28, 2014 | Craftsman 550 Torque 22 in Deck 2n1 Side...
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
Need pamphlet for Briggs,Stratton Eastern Lawnmower 2007 Took lawnmower apart, cannot find book on how to put it back together.
You must have model numbers to get any real help. If you mean you took the motor apart, you could go to www.briggsandstratton.com/ and download a manual.
Find your model number on your motor and enter on web site.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
How to replace the pull cord on a Scotts lawnmower SP6211 Roger
pull the starter housing off, take out the old rope, rotate the starter counter clock wise 5 to 6 times were the to holes line up stick a screw driver throw the holes to hold it in place. feed the same ty-ip rope from out side in throw then tie off. your going to need about 6 to 7 feet. let the pulley pull the rope in
Oct 13, 2009 | Garden
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Crafsman Eager 1 6.75 HP lawnmower wont start
I have an Eager 1, as well and when I try to pull the cord it does not turn at all. It's stuck. I hit a tree root and since then I have had problems with it. I have 2 mowers so it was not used last year at all. Gas was drained and it was stored in a shed. Anyway, I know nothng about mowers other than spark plugs, gas, oil, sharp blades and filters. Is the motor seized? Thanks
Feb 15, 2009 | Garden
Garden Logo
192 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
