Question about Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12
The cooling fan in my Freedom 25 is inop. Can it be replaced?
    Problem Solver:
  • 17 Answers
Yes, *if* you can find an exact replacement and get someone to sell it to you. In order to protect their propriety designs, Xantrex only provides OEM replacement parts to its factory authorized service network, but you might find one of them locally who would be willing to sell you the part, especially if the unit is on a boat (a Marine Freedom 25?), and can't be brought to them.
Posted on Sep 27, 2010
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Fan not working
Hi, Anonymous for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://absolutelyscooters.net/service-manuals.html
CF250 Water cooled parts
http://www.cfmoto.cn/download/?cateId=1&Id=16
CF Moto 250 Freedom Scooter 2007
CF Moto Freedom Fashion 250 Scooter Review
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 19, 2014 | 2007 C_F Moto 250 Freedom Scooter
My cf moto 250 is getting hot every time i ride it where is the therostste
Hi, Bwp1760 and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
cfmoto v5 overheating
Yahoo Groups
Jul 01, 2011 | 2008 C_F Moto 250 Freedom Scooter
Electric fan does not turn causing engine overheating when car isn't moving. Turning on the heater helps.
The inoperative cooling fan needs to be diagnosed,run the engine until it reaches 229degrees and seeif the fan gets power to turn on if so then replace the fan if not check the wiring and cooling fan relay and repair or replace as needed.
Jul 28, 2010 | 1994 Ford Taurus
Where can I find parts for my Freedom 20 Inverter/Charger near Virginia Beach, VA? The cooling fan is inoperative.
Contact Tekris Power Electronics
They are in NJ. Ph 732 938 4996
They know the Freedom units very well, I send all of my dead ones there. Good luck
Sep 11, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Check engine light error code 480
P0480 Cooling Fan I Control Circuit Malfunction
Chrysler has issued a TSB (#18-004-07)containing the fix for an inoperative cooling fan on 2005-06 Caravans and Town & Country vans with the 3.3L or 3.8L engines. The problem usually occurs after driving in heavy snow conditions where snow and ice form at the bottom of the fan shroud and block the fan blade. This condition also sets a P0480 code in the PCM. The fix requires a PCM reflash. If you have an inoperative cooling fan or a P0480 code, check the version label attached to the PCM. If a software update has not been performed since this TSB’s issue date of January 24, 2007, you should have the update performed before you start replacing any parts.
Dec 13, 2008 | 2005 Dodge Caravan
Need CPU cooling fan
I found this on ebay, though it says that the fan comes from an HP laptop the part number is the same.
http://cgi.ebay.com/HP-500-Cooling-Fan-KSB0505HA-TESTED_W0QQitemZ130273729071QQihZ003QQcategoryZ158886QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Dec 09, 2008 | Everex StepNote XT5000T Notebook
Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12 Logo
237 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
