Question about EPoX (EP-8KDA3J) Motherboard
My computer has an epox motherboard..it had always a problem of defaults loaded..and every time we turn it on we need to enter bios setup and change the date and time and the hard disk settings because it does not also detected it..kindly help...thank you
  • 140 Answers
You need to check the CMOS battery first , if it not having proper voltage (3V) it is to be replaced (CR2032) or check the cnos jumper settings.
Posted on Sep 27, 2010
Need to reset cmos
Restart your Sony Vaio computer. Press the "F2" key to enter the BIOS. Use the arrow keys to highlight the "Load BIOS Defaults" menu option. Select it by pressing "Enter." Highlight "Load BIOS Defaults" again and hit "Enter." This will reset all of the settings of your Vaio's BIOS back to their original factory defaults. You can now select "Save Changes and Exit" to exit the BIOS.
or
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Power down the system and disconnect the power cord. Wear an anti-static wrist strap to avoid electrostatic discharge damage to the Asus motherboard or CMOS chip or other sensitive components. Remove the cover and locate the CMOS coin cell battery and remove it from the system by gently pushing on the retaining clip and popping the battery out although on some motherboards cmos batteries are soldered in Discharge the CMOS chip by leaving the battery out of the system for up to an hour, depending upon the particular chip and motherboard combination. Replace the battery and replace the cover on the system. Connect the power cord and boot the computer. Save changes if prompted by the BIOS for system memory, drives detected, and other settings, and set the date and time if prompted at this time, or alternately set the date and time when the operating system finishes loading.
If your computer does not have a CMOS battery or you're unable to find it you'll need to do a hard reset on the CMOS using a jumper or dip switch on the motherboard. Information on finding these can be found through your computer or motherboard documentation. or you might set failsafe or optimised defaults Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart hope this helps
Dec 30, 2012 | Sony VAIO RB30C (VGCRB30) PC Desktop
My computer wont turn on lights up but wont turn on
What did you do in bios ?
You might have to go back into bios and set fail safe or optimized defaults.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Dec 22, 2012 | Abit AS8 Motherboard
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
Not boot from dvd
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
hope this helps you
Mar 15, 2012 | Gigabyte GA-6VXC7-4X-P Motherboard
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Not getting display on my system after changing some settings in bios motherboard intel S975xbx2
Turn the computer off.
Disconnect the power-cable.
On the motherboard, locate the battery.
It's silver-coloured, about the size of a US $0.25 coin.
Before you remove it, note the writing on the top.
Remove it.
Wait a few minutes.
Reinsert it, making sure that the noted writing is STILL on the top.
Reconnect the power-cord.
Start your computer, and enter BIOS SETUP.
Click LOAD BIOS DEFAULTS.
Save and Exit from BIOS SETUP.
Oct 11, 2010 | Intel S975XBX2 Motherboard
Epox EP-9NPAJ
Go into the BIOS setup and select 'Load setup defaults', save and exit.
Sep 19, 2009 | EPoX MB EP-9NPAJ NF4 RET Motherboard
Hey guys
  1. Enter the BIOS by pressing DEL button.
  2. Once BIOS screen is loaded scan the options and look for LOAD BEST DEFAULTS.
  3. Once default settings is loaded save changes by pressing F10. (Or try to find the save / quit option from menu )
  4. Just don't forget to save changes
Jun 17, 2008 | EPoX EP-4BEAV Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
EPoX (EP-8KDA3J) Motherboard Logo
107 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Greg Cann
Greg Cann
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
