Question about Neff Dishwashers
Neff S4132WOGB dishwasher - timer not moving forward - is a new timer/control panel difficult to fit
  • Neff Master
  • 17,129 Answers
It is posible that the timer is defective if there is no movement of the timer to advance and connect to the next program.
A new timer control of the same type is required to be fixed in this case but the wirings must be done correctly.
So before the timer is bought , confirm once again the functions of the motor ,and allied circuits as an estimate must be taken to decide.
Posted on Sep 27, 2010
Neff dishwasher continues to pump
Firstly if you haven't already you should probably check the flood switch with a multimeter, it may move freely but the contacts inside could be fused closed. Only the flood switch activates the drain full time otherwise it is directly controlled by the board so if its not the flood switch its probably the board. If the board has shorted you will likely see evidence of burnout on it.
Jul 08, 2013 | Dishwashers
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
Sticking programme
This could be a problem with the controller as it is not waiting for water to warm before continuing.
Water element should be checked, as well as the water thermostat switch (which may be stuck on), possibly a substitute timer fitted to make sure you replace the right part.
Jun 06, 2010 | Neff 24 in. S4443 Built-in Dishwasher
S5555 How to change the timer for washing?
Unplug the machinePop off the cap in the middle of the timer knob
Remove the clip that attaches the larger timer dial to the shaft
Remove the spring and dial
Unscrew the control panel and pull it forward
Undo the wiring harness
Remove the 2 screws that hold the timer to the panel.
Reverse the process to reinstall it.
Mar 20, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Neff Dishwasher
Telephone BSH 08705 543210 ask for spares department who are very good helping you with spares as long as you have all relevant serial and product numbers it can sometimes be difficult to get through because they are always busy, be persistent
Aug 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Leak of water in base of unit
is the plastic unit a salt chamber,depending where the hole is you may have to replace it or is it an over filling problem,its hard to know without seeing it hope this helps you.Thanks Ian.
Mar 14, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
175 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
